  • Replies 3.6k
Posted Images
MSC..... WTF!!!!!
Cue the race driver excuses. "Err ... I had a brake problem, and there was a misfire in the engine, and something strange was going on with the electrics."
Translation: "I'm too old and I should have stayed retired."
Nice work Capt'n Chin, a good quali time (and another needle in SV).
Big night tonite, Formula1 + GER vs AUS marathon.
I can't wait to see how the tyre battle works out in the first 5-10 laps.
I've got 1.5L of Red Bull to keep me awake :P
Good to see MW giving it his all on his final qualy lap, even tapping the wall of champions in the process, just to stick it to SV aain :ninja:
Red Bull opted to change the RB6’s box as a precautionary measure. It means that Webber’s team mate Sebastian Vettel, originally third on the grid, now joins Hamilton’s McLaren on the front row.
very convenient... wonder if helmut had any influence over that decision???
Felt like saying something similar but restrained myself. Until now
I suppose it would have been more suspect if all would have gone according to plan and then Webber were to conveniently suffer a gearbox failure during the race.
Yeh, i am sure there is nothing to it. But shame is from this point onwards there are going to be those people that just 'have to wonder"
But its one of this things, all the gremlins this season have been in Vettels car so is about time for Webber to share the pain
    • Did you take the MX5 for a Blat around the Track at all?
    • LOL, "they said it might be slippery"..... 30 seconds in your off, 60 seconds in white twin backs into the corner That new track looks good, and the Datsun was chopping cars quite nicely
    • I'll get one of these also just for giggles
    • I bought 6 new spark plugs to compare readings. They will be here tomorrow and ill see if meter is far off if it all. I know one is at least reading 0 so its best replace all anyway if one is bad, from experience. I still have to test the harness just to be sure its not a double issue and I waste my time haha-the old plugs are iridium I always thought those lasted more than 50,000 km.
    • If you take the top half of the intake off you can unbolt the flap off the shaft and leave the shaft in there blocking the hole. Then you can remove the little vacuum canister off from under the manifold and get a spare vacuum line to run to the ECU. I can take some photos of it later. Probably best to get the vacuum source to the ECU sorted first though. Mine all worked mint with the base map from the GTT an I've pretty much let the closed loop sort the fueling and took 1 degree out of the whole timing map.
