  • Replies 3.6k
Posted Images
So.... apparently in 2013 F1's will be 1.6L Turbo 4cyl cars (with max 10,000rpm).
Guess we'll see a new wave of manufactures like Hyundi and Mitzibishi coming through!
Only cool thing is the return of ground effects as well.
it will be horrrible
But anyway, we find out how much the fine will be for team fuzz today. Doubt it will be a points deduction, just a bit of pocket change and we'll all move on
Sets a precedent at least. Hopefully it means we get some consistency in the penalty system
Please, please tell me this is a bad joke? You are kidding aren't you?
Edit; Oh no, you aren't kidding :D
I feel physically ill.... YES, I remember the turbo era, it was wonderful, but those engines (even the four bangers) were 850 to 1200hp, not a piddly 650 that this proposed reg brings :D
"Apr.26 (GMM) F1 teams are close to agreeing upon a new engine formula for the six-year period beginning in 2013.
Until then, development of the current 2.4 litre V8s will remain ‘frozen’, to be replaced thereafter by similarly powerful engines that use less fuel, emit less pollution and are affordable for the small teams.
Spain’s El Mundo Deportivo newspaper said an in-principle agreement has been reached for a four cylinder, 1.5 litre engine equipped with a twin-turbo and direct injection.
The new formula would reportedly also involve KERS.
“If F1 has to develop something helpful for real (road) driving conditions, then the best solution is for an engine that is turbocharged and GDI (gasoline direct injection,” Ferrari CEO Amedeo Felisa told Autocar magazine at the Beijing Motor Show.
“That is what we would support,” he said.
Mercedes’ Norbert Haug agrees that smaller engines are likely for reasons of consumption and emissions, but warns that high technology needs to remain a crucial focus.
“If you fly from Europe to Japan on a 747, you would use more fuel than an entire F1 season. We need to see the whole picture,” he insisted."
Paddock Talk's thoughts on this; "PaddockTalk Perspective
We continue to shake our heads over this lunacy. If Formula One isn't going to be significantly different as the pinnacle of racing, then they are acting like fools.
In our minds the super-rich billionaire owners are trying to dumb down the sport to save themselves millions and pocket that extra cash rather than put it back into research and development which benefits everyone."
Edited by Marlin
The engines in the 80s were 1500cc. They weren't exactly washing machine engines ... I know they'll be restricted but they'll get around that. Not saying we'll see 1500 bhp but I think they can get at least the same power they are now. Don't forget, even at 650 bhp that's still 1000 bhp/ton. Not bad in anyone's language ...
can't do anything more for mechanical grip- they already run slicks and tricky LSD's
going back to ground effects means the grips levels shouldn't change as much when cars are in close proximity
    • Hi guys my TPS voltage is reading over 2v at idle.  My Haltech ECU is reading around 40% throttle position at idle also which is really strange. Note the actual throttle position sensor is brand new…    anyone have any experience with this or know how to calibrate it on Haltech ?
    • The OEM disk will not work on any AEM ECU, you need to use the one they made. You shouldn't have to flip the CAS or whatever you were describing, if you set the ignition sync offset correctly it can't backfire. Make sure you're using a spark plug lead on coil 1 instead of the timing loop to avoid weird issues with the timing light. Double check that your timing settings are actually correct, like is the 24 tooth configured correct or should it actually be 12 teeth for 1 crank revolution? I also found this: 305817248-AEM-Undocumented-Settings-v1-2.pdf
    • Yeah, I don't believe the M35 uses a deadhead system.
    • Have you done your thinking backwards? 3 bar, 43.5 psi pressure drop being the presumed specification for an injector, means you need 3 bar upstream when they are firing into atmospheric pressure, and more upstream pressure than that when on boost (you add your boost to your rail pressure to maintain 3 bar across the injector) and you need..... less pressure upstream when you have vacuum in the manifold. So, presuming that you're idling at -10 psi, then you only need ~23 psi in the rail. I realise that I did not need to say all of that to you specifically Matt, once you'd realised your mistake. It's mostly there for complete clarity for others.
    • Have you reached out to the guys at Spool Imports? They are a Ross dealer, I can imagine they would have the rings just sitting on the shelf (I could be wrong).
