  • Replies 3.6k
Posted Images
Well it seems RBR dont want to win the championship, rather they want to leave the door open for Alonso. From what i can gather of the Korean GP layout McLaren and Ferrari will be stronger then RBR....so Alonso can easily sneak in there for the WDC. Rather if they had pite Webber 2 laps earlier then Vettel he would have got the over and under done and the WDC would be looking a lot better for one of their drivers!
But, at least it will be good to see whoever wins it will be winning it on merit.
/...and again. How good was Kobayashi!!!!
So, both RBR drivers were slapped on the wrists...."recpect one another children" ... but this weekend is going to end in tears for RBR.
It seems clear already, this early in the weekend that they are racing themselves. RBR dont chase the timesheets on Fridays, my memory tells me every time they have been comfortably quicker in FP1 then they only ended up going quicker and gapping the other teams
So, this weekend seems to be the sphincter of the universe Rd2....Vettel wants points, is desperate for points and Webber will need this win with his team mate behing him to give him a gap to Alonso, and put Vettel out of the running. Assuming Webber, Vettel Alsonso (Maybe Kuz can sneak into 3rd???) then it means Webber will have 21 points on Alonso and 28 on Vettel....
IF, we reverse it and Vettel bags 1st with Webber behind him it means Webber only has 14 points to both Alonso and Vettel....surely this is far too tight for RBR going into the final 3 races. Dont think RBR or Webber want the win given to him....but Webber really needs to show the pace he has shown in past years at Suzuka this weekend as he has a quick team mate and its critical he beats him this weekend.
Playing with the numbers, if Webber bags a win in the next 4 races it really only means he needs 3 3rds to sew it up provided Sebv doesnt win the other 3.
So, if there are any side by side action, is it going to be another bash-clash lottery dip to see who still has a drivable car? I suspect Vettel will ptu Webber to the sword thinking Webber will protect his points lead and take 18 points...will Mark let him push him around?????
very prophetic troy.
lol, should have been a 'switch to lean map' for seb 2 laps from the end and webber cruise past for a win and a decent lead into the final 3 races.
KING KOBAYASHI!
WORD! Kobe is the man. nothing better than repeatedly dishing the chop on the same corner lap after lap after lap. he must have been a lawnmower in the suzuka circuit run off and infield as a teenager and has studied every square milimeter of tarmac on those lazy summer lawn mowing expeditions.
he's the new taku without all the senseless crashes.
yeah they are nuts. all this 'we don't favour anyone' strategy (if you can call it that) is going to cost them a WDC any moment now. unless webs can battle through (god I hope he can). come on old son!!!!!! GO WEBBER!!!!
I'd love to see Alonso take another one, I can't see it happening though (prove me wrong Fernando!).
As long as Vettel doesn't win it...
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
    • I think he was only proposing to use the wire, not the sender. Simply because it runs from the right place to the right place. Personally, I wouldn't hack up the factory wiring like that. I'd just lay in the Defi loom.
    • From memory it wasn't too hard to simply see which wire ran where when you plug that in. Unfortunately also from memory the OEM sender does not use the same configuration 99.9% of gauges run. So in other words if you connect the signal wire that was running to the OEM gauge to your DEFI gauge you might find your oil reads at 200C or some other incorrect value. I remember having the same line of thought and then running new wires/senders to match the gauges I have. The pinout is available in the R34 workshop manual.
