  • Replies 3.6k
Posted Images
yeah I can't believe webber would intentionally position his car hoping for an accident. that's just nuts and suicidal. I doubt there is a driver on the grid who would do that. well maybe schuey would...
I'm not saying what I think he was doing. I'm just saying what I saw. He holds it on full lock to go back across the track. why? I don't know, but saying he was trying to continue racing after slapping into a concrete wall by swerving back across the track into the path of other cars makes far less sence than Berger's theory.
besides, drivers think they are bulletproof. And I think Mark has enough mongrel in him to play a bit of dirty pool when the situation calls for it.
If you look at the reverse camera angle, as in the one pointing down the track behind the cars coming out of the corner that Webz spun at. You can see that after he had hit the wall, and was rolling back, his front right wheel was inches off the ground. Maybe he did, maybe he didn't, but I think that contact donald ducked his suspension.. If so, I am curious as to why he didn't put the skids on... :)
You can stay but expect a bit of residual Hamilton is a douche sentiment around here.
Being considered a douche is a big improvement on the consensus a couple of seasons ago.
Nah everyone still thinks he's a f**king flamin mongrel.
Berger is farken clown in this case who just hasn't had his name in the press for a week!
so like... a million times this?
It's one thing I've noticed about the bugger... once every 2 months or so, go against the grain to have forums like us talk his shit up...
bo-ring...
bo-ring...
He's just said he doesn't get to dock with Vettel anymore.
He's like Columbo (but without the charm)- Just when you think he's gone, he comes back for an unsolicited encore
I'll open the champers if he gets the A at the end of this season, and yet he'll likely still be gridding up courtesy of a bottom-feeder team come 2011
Well, not long now until practice is underway...and there are reports of rain for quali. I really think the elements mean that RBR are less likely to get the win...ans also bad news for those hoping for an engine failure for Alonso. Only good think is Webz normally pips Vettel in wet quali so here is hoping
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
