Spotted Amaru(?) the other day in Jerra :rolleyes:  Love the pearl paint work...  I've still got to meet up with you and get the leather gear boots sorted out....  Damn the days aren't long enough.
J
Nah,that was me!I dare you to ask Amaru where his car was at that time...
https://www.sau.com.au/forums/topic/30059-spotted/page/68/#findComment-1046541
J
That would be LTSJayce you saw, he has the shmick pearl paint, mines just plain white :D
And yeah, cars still off the road, expecting it back today or tomorrow, so will have to organise a time then to get those gear boots done :D
https://www.sau.com.au/forums/topic/30059-spotted/page/68/#findComment-1046542
Did you stop at Integra? Is my damn sump back on yet? :D
Ha ha!Actually,it was a flying trip for me:just had to drop a few articles into Ed'.There was a good collection of 'Lines including yours this morning-just wasn't looking for your sump!!
https://www.sau.com.au/forums/topic/30059-spotted/page/68/#findComment-1046857
Yeah i reckon :D And on the hottest day in the last 8 months :D
I was worried about squeezing past the baracade into the carpark as the Skyline's a bit wider than the other 2 cars i drive normally, but luck was on my side and just followed someone in this morning.
https://www.sau.com.au/forums/topic/30059-spotted/page/68/#findComment-1047117
Damn, I'm out of wack with who is who !!
Good to see you LTSJayce, nice car :D
Amaru, yepp, no problems.  I think my weekend is going to be written off but Thursday after work is OK so far.
J
Thanks for the compliment!Right back at ya with the Stagea!My better half actually spotted you first that day at Jarra'-she was really excited,going "Hey!That's a Stagea,isn't it?!"I thought that was well spotted for the Subaru nut she is!Ah,they learn so fast...
https://www.sau.com.au/forums/topic/30059-spotted/page/68/#findComment-1047957
    • I get that taking off the head is best but that's a bit much for "just" valve seals. I was just under the impression that one would be able to rotate to TDC and be able to temporarily drop the valve without losing it and effectively having to remove the head to then recover it. I never knew people actually pushed rope into the cylinder to do valve seals hahaha So just to confirm, just going to TDC will not work? In that case I know when I do valve seals I'll maybe just remove the head and do some other things while I'm there, or just wait until I do an engine build.
    • The old approach was to fill the cylinder/chamber with a length of rope pushed in through the sparkplug hole. The new approach is to connect compressed air to the sparkplug hole and fill it with enough pressure to push the valves up. Doing either of these things with the head on and the engine in the car is a lot less pleasant than doing it properly.
    • Can't you put the pistons to TDC and then do the valve seals? Or will the drop down too far to pull them back up?
    • One thing I can tell you is, do it properly the first time. If you encounter unexpected problems just let the car sit for a week or two if you have to get some other parts or figure stuff out.  I'd have said go and use as many OEM parts as possible but since you want to change the turbo later on a custom kit is probably the better choice. Since I have no experience with RB25 just compare parts diagrams and images before buying a line kit and it should be easy to see if it has everything you need. Amayama has very good parts diagrams and part number lists, that is what I used a bunch to figure out what I might need. And don't forget to plan ahead and possibly renew other stuff that's easy to get to while you're in there doing the turbo lines. Happy wrenching
    • Update 4:   Hi all, good news. Engine is running and all the gaskets and seals seem to be working as intended. No leaks so far, even the JB Weld seems to hold. I flushed out the old coolant a few times and put in fresh coolant, not Nissan stuff, I decided to try the Ravenol Protect FL22, they claim it works for a wide variety of JDM cars and the opinions on it by some people were pretty good. And it has the nice poison green color! And man am I glad I bought a coolant system tester earlier this year, vacuum filling works wonders on this engine. I can definitely recommend this to anyone still doing it the old school way. All you need is compressed air supply. Will have to do a small test drive as soon as I can, I removed the gauge cluster again as the tacho needle was still bouncing around a bit but it was much better than before already.  I also found some cracks on all 4 tires inner and outer sidewalls. Apparently these tires should 't be parked on for extended periods or be kept under 0 degrees during storage, which I did not know. Clearly the previous owner didn't look into those details either, he probably bought them just cause they are cool semi-slicks. I'm just wondering how tf I am supposed to reach 30-80 degree tire temperatures on the public road consistenly, these tires were never going to work for my use case. I'll probably order Continental SportContact7 ones as these are the best allround summer tire available right now and I don't think I'll need anything crazier for now. Do let me know if you have experience with various tires and which ones you recommend.
