Spotted that gorgeous red 32 gtr at about 5 30ish this afternoon driving down the main street of queanbo.
Then about 10 to 6 a maroon 33 with vic plates on it, so not sure anyone on here???
Last a white 32gt-r very nice went past to quick to get a good look tho *sigh* gold rims by da looks of it? Going past hungry jacks in queanbeyan aswell.. good day for spotting :(
https://www.sau.com.au/forums/topic/30059-spotted/page/88/#findComment-1097498
Yep sure do.
I think it was me who drove past you in the Stagea yesterday.
Had a few personal things going on so have been a little spaced out lately.
Will make sure I wave next time I see you.
Cool. i've seen you a few times waiting in peak hour along haydon drv. i'm always going the other way during peak. it's so quick getting through traffic
https://www.sau.com.au/forums/topic/30059-spotted/page/88/#findComment-1099526
spotted tonight WHYTRY boosting at very high revs past the formal that was on at rydges great work lookd very very good and sounded swarve did not seam to be running as rich as every other time i seen it...
that was on low boost, in which it runs a bit on the lean side to conserve fuel, for when i cruise around.
high boost, it runs on the rich side, thus i didn't want to wipe out everone that was standing around. haven't had it on high boost for a loooong time due to the clutch being on the 'hows it going side'. will replace it after i've finished with a few more bolt on mods.
needless to say the coper wasn't too happy bout it after he pulled me over, was bout to give me ticked, when a snaper head in a commodore came speeding round the corner and went after him. long live the idiots in commowhores.
https://www.sau.com.au/forums/topic/30059-spotted/page/88/#findComment-1100010
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
    • Carrying out some engine due diligence before my first drive in a 260RS that has been in storage for 10+ years, and found two lines that are susposed to be plumbed into the boost control solenoid. One of the lines (the wastegate boost supply line) to actuate the gates, had a bolt in one end blocking it. The other line (main boost signal line) from the very rear of the intake manifold (RB26DETT) and runs up to the boost controller had this pill in the end of it as seen in photos. Other than the obvious (T28 Ceramic turbos might well be cooked)  Can anyone shed any light on if there is any validity at all with this mod, bleeding a constant fixed rate of manifold boost pressure off through this 3mm hole?  Is it deliberate?  Was this a 90s Jap mod done to RB26's? Or has someone just fitted this without any idea of what happens to ceramic T28s if they are not gate controlled?
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
