Got Ow3ed something hardcore by a Blue S15 trial body kit, 19's and one nicely worked engine, running 16psi apparently but had external wastegate so not running stock turbos very nice indeed, and great guys too.
Just quickly-you wouldn't happen to own a white R34 GT-T like your avatar photo,wouldya? Coz I spotted a neat car as per described,and parked next to it,at the Shell servo' in Fyshwick this afternoon...and there was a gunmetal grey R33 GTS(T?) parked the other side of the servo,too.
https://www.sau.com.au/forums/topic/30059-spotted/page/118/#findComment-1176949
I spotted that Blue S15 once, does it have chrome windscreen wipers or something? Only thing i can fault it for :rant:. he was having a squirt against some guy in a REX in tuggers from the lights to the form one lane infront of the shops. He won, car sounded wicked too.
https://www.sau.com.au/forums/topic/30059-spotted/page/118/#findComment-1177875
saw a burgandy r33 in dickson had like black/carbon fibre inserts were the rear lights are you know like that triangle thing :rant: it had gtr badges though i dont think it was. had gtr front bar not sure of the side skirts and had a super dupper rear wing.
https://www.sau.com.au/forums/topic/30059-spotted/page/118/#findComment-1178717
spotted 1 silver stagea rs4 at autotech today with a bloke holding a unichip shitting in it. terminal, that yours??
also, a stock-looking black 33 with an obscenely loud and horrible sounding exh. drive past subway in fishies. if thats anyone here, please change it. it sounded like a carby lancer with a cannon!!! *cringe*
d
https://www.sau.com.au/forums/topic/30059-spotted/page/118/#findComment-1178736
you had me worried it was me ;) but i havent been to fyswick in ages so i am safe :D
also would have to agree funniest miss spelt word ever ;):)
https://www.sau.com.au/forums/topic/30059-spotted/page/118/#findComment-1179505
spotted 1 silver stagea rs4 at autotech today with a bloke holding a unichip shitting in it. d
Yepp, that was my beast :)
Unichip didn't go in cause they were having problems locating the wire for the TPS. This is sort of a blessing, cause I was playing with the TPS and trying to find the wire on the ECU for it. Found the wire and I also found out why I get a slight flat spot when it's cold... The TPS needed adjusting, now it's all good and not giving false readings when cold (that's why that couldn't find the output) I'll go back out there tomorrow and tell them.
J
https://www.sau.com.au/forums/topic/30059-spotted/page/118/#findComment-1179734
Yet?
Joining me and jay in the unichip fraternity at some stage?
LOL - yepp, soon I hope !! Just had a slight delay with getting it in. APS said that I'm the first to put a Unichip and the boost control module into a Stagea, so we've had to make up our own wiring diagram etc...
I 'think' it's all good to go now.... hopfully....
J
https://www.sau.com.au/forums/topic/30059-spotted/page/118/#findComment-1179737
Soptted a R33 with Gold rims today at the chisholm round about. was in the back seat of a lancer.... gave you some looks... saw a lil smile..
Also a Maroon R33 with GTR badge in the front grill, coming out of Qbn tonight..
Was also in the lancer...
https://www.sau.com.au/forums/topic/30059-spotted/page/118/#findComment-1180328
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
