Spotted Terminal's Stagea parked in Civic. Love the wing at the back, looks VERY nice! i was parked near you, few spaces back. You were gone when i came back so i don't know if you saw my car or not.
Nah champ, i'd left my car there overnight due to um... beer. anywho, i was feeling fairly surley when i came to pick it up, so i didn't really notice anything
https://www.sau.com.au/forums/topic/30059-spotted/page/129/#findComment-1205110
Whoo hoo..
About ten minutes ago. Chameleon painted R33, at the intersection of Gininderra and Kingsford Smith. Stopped at the pedestrian crossing because two tarted-up 12 (?) year old girls were standing near the end of the crossing. Realised they weren't actually going to cross, so revved it, dropped it, and smoked sideways out of the corner...
https://www.sau.com.au/forums/topic/30059-spotted/page/129/#findComment-1205212
Whoo hoo..
I love Alfs car
https://www.sau.com.au/forums/topic/30059-spotted/page/129/#findComment-1205224
Was at Jerrabomberra Pub earlier this evening for a birthday party, spotted an off yellow (BA Falcon Acid Rush?) R33 series 2 GTS-25t.
And now for something completely different.....
On the way home from Civic about 40 minutes ago, I was witness to the comprehensive drilling of a T2 Falcon TS50 by a VX2 Commodore SS. It was awesome fun to watch, even if I am a Ford fan....those things go like shite for 220kw worth of Windsor V8. I was in the same lane as the Falcon but behind it, so I had the hammer down to see how far behind I'd fall, and I was only about 2 cars behind it by 90km/h when I backed off..... I so can't wait till my Neo is in now..... just for the shock factor
Oh and the Falcon lost by about 5 cars :wassup:
https://www.sau.com.au/forums/topic/30059-spotted/page/129/#findComment-1205597
spotted just then... a Silver R33 S1 at erindale... with similar vinyl as the R34 on 2F2F.. and 5 spoke deep dish wheels.
Saw that yesterday afternoon at bunnings at tuggeranong on the back of a tow truck
Last night i saw Terminals Stagea, looks awesome with that wing!
https://www.sau.com.au/forums/topic/30059-spotted/page/129/#findComment-1206296
    • When I said "wiring diagram", I meant the car's wiring diagram. You need to understand how and when 12V appears on certain wires/terminals, when 0V is allowed to appear on certain wires/terminals (which is the difference between supply side switching, and earth side switching), for the way that the car is supposed to work without the immobiliser. Then you start looking for those voltages in the appropriate places at the appropriate times (ie, relay terminals, ECU terminals, fuel pump terminals, at different ignition switch positions, and at times such as "immediately after switching to ON" and "say, 5-10s after switching to ON". You will find that you are not getting what you need when and where you need it, and because you understand what you need and when, from working through the wiring diagram, you can then likely work out why you're not getting it. And that will lead you to the mess that has been made of the associated wires around the immobiliser. But seriously, there is no way that we will be able to find or lead you to the fault from here. You will have to do it at the car, because it will be something f**ked up, and there are a near infinite number of ways for it to be f**ked up. The wiring diagram will give you wire colours and pin numbers and so you can do continuity testing and voltage/time probing and start to work out what is right and what is wrong. I can only close my eyes and imagine a rat's nest of wiring under the dash. You can actually see and touch it.
    • So I found this: https://www.efihardware.com/temperature-sensor-voltage-calculator I didn't know what the pullup resistor is. So I thought if I used my table of known values I could estimate it by putting a value into the pullup resistor, and this should line up with the voltages I had measured. Eventually I got this table out of it by using 210ohms as the pullup resistor. 180C 0.232V - Predicted 175C 0.254V - Predicted 170C 0.278V - Predicted 165C 0.305V - Predicted 160C 0.336V - Predicted 155C 0.369V - Predicted 150C 0.407V - Predicted 145C 0.448V - Predicted 140C 0.494V - Predicted 135C 0.545V - Predicted 130C 0.603V - Predicted 125C 0.668V - Predicted 120C 0.740V - Predicted 115C 0.817V - Predicted 110C 0.914V - Predicted 105C 1.023V - Predicted 100C 1.15V 90C 1.42V - Predicted 85C 1.59V 80C 1.74V 75C 1.94V 70C 2.10V 65C 2.33V 60C 2.56V 58C 2.68V 57C 2.70V 56C 2.74V 55C 2.78V 54C 2.80V 50C 2.98V 49C 3.06V 47C 3.18V 45C 3.23V 43C 3.36V 40C 3.51V 37C 3.67V 35C 3.75V 30C 4.00V As before, the formula in HPTuners is here: https://www.hptuners.com/documentation/files/VCM-Scanner/Content/vcm_scanner/defining_a_transform.htm?Highlight=defining a transform Specifically: In my case I used 50C and 150C, given the sensor is supposedly for that. Input 1 = 2.98V Output 1 = 50C Input 2 = 0.407V Output 2 = 150C (0.407-2.98) / (150-50) -2.573/100 = -0.02573 2.98/-0.02573 + 47.045 = 50 So the corresponding formula should be: (Input / -0.02573) + 47.045 = Output.   If someone can confirm my math it'd be great. Supposedly you can pick any two pairs of the data to make this formula.
    • Well this shows me the fuel pump relay is inside the base of the drivers A Pillar, and goes into the main power wire, and it connects to the ignition. The alarm is.... in the base of the drivers A Pillar. The issue is that I'm not getting 12v to the pump at ignition which tells me that relay isn't being triggered. AVS told me the immobiliser should be open until the ignition is active. So once ignition is active, the immobiliser relay should be telling that fuel pump relay to close which completes the circuit. But I'm not getting voltage at the relay in the rear triggered by the ECU, which leaves me back at the same assumption that that relay was never connected into the immobiliser. This is what I'm trying to verify, that my assumption is the most likely scenario and I'll go back to the alarm tech yet again that he needs to fix his work.      Here is the alarms wiring diagram, so my assumption is IM3A, IM3B, or both, aren't connected or improper. But this is all sealed up, with black wiring, and loomed
    • Ceste, jak se mas Marek...sorry I only have english keyboard. Are you a fan of Poland's greatest band ever?
