Spotted a silver S2 R33 with massive chromies going into belco mall about 4, and then passed a dark coloured (it was night) R32 on my way back from gungahlin. also i think MIVEC went past me. it was a silver FTO with a massive wing.
https://www.sau.com.au/forums/topic/30059-spotted/page/189/#findComment-1487834
To my knowledge it was purchased locally buy a certain someone who used to own a gunmetal R32 GTR with Avo turboworld stickers down the side of it... :)
EDIT: I could be wrong though, but I know in the last week a white R34 GTR V-Spec II has been added to the Canberra lineup :) Seems like theyre becoming a bit more common now prices have slipped on them.
https://www.sau.com.au/forums/topic/30059-spotted/page/189/#findComment-1488401
Nah same car, i think its the guys girlfriends car, its usually parked at BDL fyshwick. I tend to never see a girl driving it but...
Dayne
It's her's I hope she was driving it cos I certaintly havn't driven it for a while i don't think, and she drives it every where I'll have to tell her you think she looks like a guy. I hardly every drive hers cos I got my shity banged up burgendy one goes faster :) where'd ya see it by the way was it saturday morning and you drive the black one???
https://www.sau.com.au/forums/topic/30059-spotted/page/189/#findComment-1488648
Technically not a real "spotted" but anyway.....
Brian Hall Autos in Phillip have an R34 for sale in their showroom, it's a GT-t, they seem to think it's a GT-R as that's what they're referring to it as, and they've got an asking price of $45,990 on it.
I love car shops that don't know what they've got....
The funny problem is that it's too cheap for a GT-R and a bit rich for a GT-t :D
https://www.sau.com.au/forums/topic/30059-spotted/page/189/#findComment-1488883
To my knowledge it was purchased locally buy a certain someone who used to own a gunmetal R32 GTR with Avo turboworld stickers down the side of it... :D
EDIT: I could be wrong though, but I know in the last week a white R34 GTR V-Spec II has been added to the Canberra lineup :D Seems like theyre becoming a bit more common now prices have slipped on them.
that bastard!!!!! a 700horse 32 just wasn't enough was it. that is without a doubt the nicest 34 i've ever seen. and damn cp039's too!!!! its just not fair!!! *stamps feet. flails arms around and goes and sooks in the corner*
the only 34 that might tempt me otherwise would be volk's 750ps demo car. see attach and clicky.
https://www.sau.com.au/forums/topic/30059-spotted/page/189/#findComment-1489168
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
    • So, a bit of a side trip, but one that might be interesting for people with JDM cars and japanese head units. I know @Pac previously posted about a carplay/android auto adapter he installed which used the AUX input, and @V35_Paul put in one of the Tesla style units that replace both screens. The option I went with was a Lsait LLT-YF-VER5.87_2 (https://www.alibaba.com/product-detail/Lsailt-8GB-Android-Multimedia-Interface-for_1601187633672.html). Price was $1,150 for a single unit although they are much cheaper if you are willing to buy 2....$857ea. Make you you get the version 2 not version 1, it is faster and has a better UI - this is the manufacturer listing: http://www.lsailt.com/product/348.html. BTW if you've never bought from Alibaba before, don't be concerned....these guys can't stay in business unless they are responsive, ship fast etc, they were excellent (probably faster shipping than most local places) So, this was my task for a lazy Sat afternoon....looks complex but was all done in a few hours (it probably helps that I had some of it apart before so it was a bit familiar). I also decided to add a HD USB drive recorded at the same time and the unit also supports an aftermarket reverse cam (if you don't want to retain factory) and also AV in and HDMI out It looks much worse than it is, in fact in was genuinely all plug and play (no custom wiring at all). This video was pretty good (skipped a few steps), unfortunately they are an Aussie seller but no longer sell this unit (I guess Carplay/AA adapters are easier to install and much cheaper) https://www.youtube.com/watch?v=T5hJfYOB8Dg
