spotted who i think was mickGTR driving past isaacs this arvo, and before that, two yellow GT-Ts (one with the NISSAN plates, and one NSW) in the span of about 2 minutes
the one with NISSAN plates is now my former boss, for those that don't know i have moved on.
I also spotted Leigh walking through the food court at midday today in Civic.
https://www.sau.com.au/forums/topic/30059-spotted/page/201/#findComment-1551539
haha yeah i didn't think you had seen me sneak up on you so when we hit the round about i slammed it into 2nd and floored it to catch you lol.
It would have been good if we had kept going without the bloody traffic, oh yeah, i want your car  :P
I'll sell it you when the new GTR comes out :)
https://www.sau.com.au/forums/topic/30059-spotted/page/201/#findComment-1551932
Oh yeah and how many of you guys work out at Brindabella park? I swear there are like 5 skylines out there on a daily basis.
The place is a hole and it's barely in canberra, but you gotta love the cars in the carpark: a couple of 350Z's a couple of S2000's, WRX's, Skylines, a B4 etc. Almost makes the long drive out there worth it every afternoon... almost :P
https://www.sau.com.au/forums/topic/30059-spotted/page/201/#findComment-1551944
was that with my new home entertainment unit or without ??? lol that f**king thing ways heaps i had to stop every 25 meters  :lol:
Lol it was without, I'm in there every day now as i work on city walk :O yay go Veilside, he's a city lunchtime yuppy now!!!
https://www.sau.com.au/forums/topic/30059-spotted/page/201/#findComment-1552258
So that WAS you buying it at DJs! I thought you looked familiar - I was getting a digicam at the same time! were you getting a tv too? flat screen?
https://www.sau.com.au/forums/topic/30059-spotted/page/201/#findComment-1552444
Ok, here we go
During peak hour in Weston on Hindmarsh Drive:
White R33 GTS-25t series 2 coming OFF the Parkway
Silver R33 GTS-25t series 2 going ONTO the Parkway :P
Slightly after peak hour:
Stock looking silver R33 GT-R in BP Phillip
Very nice clean white/silver R31 Silhouette on Athlon Drive
7:00 ish
VeilsideR33 on Hindmarsh Drive presumable heading to trivia
Silver R33 GTS-25t series 2 turning onto Hindmarsh Drive from Melrose Drive
https://www.sau.com.au/forums/topic/30059-spotted/page/201/#findComment-1554109
i am trying to remember which guy you were i thought i met you at tsunami cruise but i dont remember what you look like. Anyways only bought the home entertainment system, TV and dvd player are to come over the next month or two :P
https://www.sau.com.au/forums/topic/30059-spotted/page/201/#findComment-1554113
Ok, here we go
7:00 ish
Yeah guilty as charged, didnt see you though, where were you?
https://www.sau.com.au/forums/topic/30059-spotted/page/201/#findComment-1554402
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
