Spotted a mangled silver R33 GTSt on the road from the Airport to Queanbeyan at the turn off for the driver training place... looked like it was a 3 car accident involving a commodore, commodore ute and the skyline... hope it was no-one off here :) (yesterday afternoon)
I wast sure if the r33 was damaged or not it was there but seemed like it was pulled over for help or sometihng. The ute was gone tho
https://www.sau.com.au/forums/topic/30059-spotted/page/207/#findComment-1593946
Gallardo's quicker than a Diablo too...
2001 Lamborghini Diablo VT 6.0 -- 3.6s 0-100km/h / 12.0s 0-400m
2003 Lamborghini Gallardo -- 4.0s 0-100km/h / 12.4s 0-400m
The last version of the Diablo still beats the Gallardo... only just :)
The Gallardo was a whole new car, the Diablo replacement was the Murcielago which has exactly the same performance.
Either way, id have any of them :ph34r:
https://www.sau.com.au/forums/topic/30059-spotted/page/207/#findComment-1594538
lambos schlambos. gimme my fezza anyday! even my poor mans ferrari will do against the lambo thanks nick! :ph34r:
and yes i was in griffith this morning. can't say i was awake enough to noice anyone really....
d
I wasn't driving anything that would be noticed.... :)
https://www.sau.com.au/forums/topic/30059-spotted/page/207/#findComment-1594834
Either way, id have any of them :D
yeah i kinda fuct my original post up, but its fixed now,
wouldnt mind a Gallardo in the shed
https://www.sau.com.au/forums/topic/30059-spotted/page/207/#findComment-1595553
spotted last night.
that 33 gtr with the roh's 2nd story par cark. and aurora and mark having food/drinks at babar. was gonna throw a thing of sugar at you but was stressed it'd bounce off and hit someone else (or i'd retard it up!) hehe :O
oh, and wallace and grommit is awesome!!! must see peeps!
d
https://www.sau.com.au/forums/topic/30059-spotted/page/207/#findComment-1596728
spotted a maroon R33 this arvo parked in russell or barton (one of the two) with a big FMIC which had ARC across the front. looked mad.
also saw a neat gun metal R32 GTR with gold wheels, outside Harvey Norman fyshwick.
https://www.sau.com.au/forums/topic/30059-spotted/page/207/#findComment-1597274
the guy that owns that gtr works there...
d
https://www.sau.com.au/forums/topic/30059-spotted/page/207/#findComment-1597534
spotted - white stagea in Bega yesterday.
Had ACT plates and a skylineaustralia sticker aswell.
Anyone here?
Would have been Marc, he owns discount tyres in belco and gunny
Spotter Sigsputnik last night going down canberra ave, had a quick chat
also spotted djhatton's car outside ACTab in dickson
https://www.sau.com.au/forums/topic/30059-spotted/page/207/#findComment-1598661
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
