forgot to mention, spotted amaru's r32 gtr forsale on scotts big boys toys website... well im pretty sure its his, has it been forsale for a while now or what?
Dayne
The company I used to work for designed the website, and it was put up to test the system out and make sure it worked ok and I just never removed it :)
https://www.sau.com.au/forums/topic/30059-spotted/page/211/#findComment-1615016
Ah okay.... wondered why i hadn't heard anything more about it!
Spotted a heapppp of skylines out last night, followed one that had DTS on the back of it for a while... also parked in the city next to a white r33 series II with chrome rims today, P plate, female driving:D
Dayne
https://www.sau.com.au/forums/topic/30059-spotted/page/211/#findComment-1615256
i keep seeing a black 33 parked down the back of the erindale carpark, across the road from maccas, with a P plate and funny looking twin tip exhaust.....
also saw a yellow 33 at the 'mobil' roundabout at erindale yesterday arvo....
https://www.sau.com.au/forums/topic/30059-spotted/page/211/#findComment-1617103
i have a feeling thats graham as it also has the same front lip as his, ive spotted it before
https://www.sau.com.au/forums/topic/30059-spotted/page/211/#findComment-1617591
    • I know I have to get a wheel alignment but until then I just need to bring the rear tyres in a bit they're wearing to the belt on the inside and brand new on the outside edge. I did shorten the arms a bit but got it wrong now after a few klms the Slip and VDC lights come on. I'd just like to get it to a point where I can drive for another week or two before getting an alignment. I've had to pay a lot of other stuff recently so doing it myself is my only option
    • You just need a wheel alignment after, so just set them to the same as current and drive to the shop. As there are 2 upper links it may also be worth adding adjustable upper front links at the same time; these reduce bump steer when you move the camber (note that setting those correctly takes a lot longer as you have to recheck the camber at each length of the toe arm, through a range of movement, so you could just ignore that unless the handling becomes unpredictable)
    • I got adjustable after market rear camber arm to replace the stock one's because got sick of having to buy new rear tyres every few months. Can anyone please let me know what the best adjustment length would be. I don't have the old ones anymore to get measurements. I'm guessing the stock measurement minus a few mm would do it. Please any help on replacing them would be fantastic I've watched the YouTube clips but no-one talks about how long to set the camber arm to.
    • Heh. I copied the link to the video direct, instead of the thread I mentioned. But the video is the main value content anyway. Otherwise, yes, in Europe, surely you'd be expected to buy local. Being whichever flavour of Michelin, Continental or Pirelli suits your usage model.
    • Continental have consistently beaten the absolute shit out of every other performance tyre in Wet/Damp/Cold conditions and give up a little bit of time (half a second at most) in the dry. Almost like it's engineered for German conditions or something. I'd def give those a try.
