wow! no not top secret. from what i know about the car its been built in australia by people that know a thing or 2 about fast gtrs... hehe. the camcovers should signify something built with lots of... umm... jun bits perhaps??!! :)
what a work of art!
i've been waiting to meet this guy for how long now!? i remember when i was working at kingston hi-fi seeing this car (about 2 years ago or so??) and then it just dissapeared! i've heard so much about this car i can't believe its actually on the road and running (finally!)
i'll be the first here to call reserve shotgun rights when its done its time doing the whole running in thing.
david
https://www.sau.com.au/forums/topic/30059-spotted/page/213/#findComment-1619422
yeah deffinetly some nice machines getting around! cant wait til mines gets out there :) That RH9 is a damn fine machine, and wasn't there a Red R32 that was getting around aswell that raced that umm RX3 or sumthin?
Was a gunmetal R32 and he sold it and now owns RH9 :)
https://www.sau.com.au/forums/topic/30059-spotted/page/213/#findComment-1619521
nice one smartass :unsure: who owns it now????
d
From what I know it was partially stripped and sold... could be wrong though :)
Also forgot to mention spotted djhatton drunk as a skunk in civic on saturday night :D
https://www.sau.com.au/forums/topic/30059-spotted/page/213/#findComment-1620153
Bloody BMW drivers!!!!! :P
was driving on the way to work today, when i came across a car in the right hand lane, doing about 65kph. so i happily decided to move into the left hand lane to pass it, so i did. then i happen to come across another one and did the same thing, as we were pulling up to a set of lights (about 100m away!). lights go green, i take off (wasn't racing, but was moving quicker than everyone else), then from no where, this silver BMW decides to sit on my arse. so i speed up a little, but he doen't move. coming into the big roundabout at woden, i get a little tired of this knob, and gun it through there, loosing him. then he comes back along the straight, so he sits on my arse again. im passing a truck, so i cant move over, when i do, he races up beside me and shakes his head and makes a fist at me??? as if to say "you bloody hoon"! What The F*ck?!?! he was sitting on my arse and causing road rage when it was totally uncalled for, and im at fault??? that just really pissed me off.... im about to punch the computer screen it makes me so angry!!! aaaarrrrrrrrgggggghhhhhhh!!!!!!!!!!! :):):angry::angry:
*end rant and rage*
https://www.sau.com.au/forums/topic/30059-spotted/page/213/#findComment-1621147
Slightly off topic: I rate DJ Hatton's avatar-Silent Bob rocks! For those that don't know,check out the movies Clerks,Mallrats,Chasing Amy,Dogma and Jay and Silent Bob Strike Back...
true i already have clerkys, mallrats chasing amy and jay and silent bob strike back great movies
https://www.sau.com.au/forums/topic/30059-spotted/page/213/#findComment-1621148
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
