My favourite response to people tail gating is to give the brakes a gentle push...
Bloody BMW drivers!!!!!  :D
was driving on the way to work today, when i came across a car in the right hand lane, doing about 65kph. so i happily decided to move into the left hand lane to pass it, so i did. then i happen to come across another one and did the same thing, as we were pulling up to a set of lights (about 100m away!). lights go green, i take off (wasn't racing, but was moving quicker than everyone else), then from no where, this silver BMW decides to sit on my arse. so i speed up a little, but he doen't move. coming into the big roundabout at woden, i get a little tired of this knob, and gun it through there, loosing him. then he comes back along the straight, so he sits on my arse again. im passing a truck, so i cant move over, when i do, he races up beside me and shakes his head and makes a fist at me??? as if to say "you bloody hoon"! What The F*ck?!?! he was sitting on my arse and causing road rage when it was totally uncalled for, and im at fault??? that just really pissed me off.... im about to punch the computer screen it makes me so angry!!! aaaarrrrrrrrgggggghhhhhhh!!!!!!!!!!! :D  :angry:  :angry:  :angry:
*end rant and rage*
https://www.sau.com.au/forums/topic/30059-spotted/page/214/#findComment-1623297
what ever happened to that avo-schtickered 32???
To set the record straight, this car is heading back to canberra, its track days behind it, it will however be menacing in its street clothes...
P.S. watch for it in about a month or so... B) B)
https://www.sau.com.au/forums/topic/30059-spotted/page/214/#findComment-1623424
i've found that its never worked, nor has it ever worked on me.....
Yeah not much of a fan for that either.. and can cause you some stress if the guy isnt switched on..
I instead just slow down to a stupid speed, and just ride at that for a while.. it gives u a bit of a laugh.. and pisses them off :P
https://www.sau.com.au/forums/topic/30059-spotted/page/214/#findComment-1624325
spotted a chopped up front bar on a grey s1 33
That would have been me if it was around lunchtime. It's my old R33 i sold ot my brother, i'm getting the whole bodykit replaced in a week and a bit. A bit embarassed driving it at the moment
https://www.sau.com.au/forums/topic/30059-spotted/page/214/#findComment-1625540
That'd be Theo with the 34 GT-R.
Spotted this evening on Hindmarsh Drive about 6:40 ish
- Yellow R34 25GT-t
- Grey R32 GTS-t 4-door
About 15 seconds apart from each other
Does Theo have a v-spec with a (sorry to say it mate) horrible looking front spoiler?
https://www.sau.com.au/forums/topic/30059-spotted/page/214/#findComment-1625935
As the guys have already suggested;no,it hasn't got a horrible looking front spoiler,but it does have it's standard V Spec' bodykit in pristine condition. That car is flat out HORN,and there would only be visually-challenged or slightly retarded people in the world that think a standard R34 GT-R looks anything but sex-on-wheels...Maybe you saw someone else?(Exactly how many OTHER Bayside Blue GT-R's could it possibly be?Was it possibly be an R34 GT-T?).Oh,spotted a silver R33 GTS-T threading thriugh the traffic on Limestone Ave on Tuesday morn';whoever it was wouldn't have spotted me-I was on my bike riding to work,clad in Lycre(TM,Patent Pending...LOL)and carbon fibre stuff...
https://www.sau.com.au/forums/topic/30059-spotted/page/214/#findComment-1626264
    • For DBA, check out their guide table here. https://dba.com.au/wp-content/uploads/2023/01/Direct_Replacement-Guide-2021.2.pdf   Additionally they have some other guides and info on how to make sure you choose the right pad.
    • Sorry, just assumed that talk of coloured pads meant EBC red/green/yellow/shit stuff. I don't know the DBA pads, but it's a reasonable bet that they will be OK. DBA make good stuff generally. Those 4000 series rotors I linked to are very good. I may well replace the RDA rotors I have with those when required.
    • The average previous owner for these cars were basically S-chassis owners in the US. Teenagers or teenager-adjacent. I often tell people that neglect is easier to fix than something that was actively "repaired" by previous owners.
    • Update 3: Hi all It's been a while. Quite a lot of things happened in the meantime, among other things the car is (almost) back together and ready to be started again. Things that I fixed or changed: Full turbo removal, fitting back the OEM turbo oil hardlines. Had to do quite a bit of research and parts shopping to get every last piece that I need and make it work with the GT2860 turbos, but it does work and is not hard to do. Proves that the previous owner(s) just did not want to. While I was there I set the preload for the wastegates to 0,9bar to hopefully make it easier for the tuner to hit the 370hp I need for the legal inspections that will follow later on. Boost can always go up if necessary. Fitted a AN10 line from the catch can to the intake hose to make the catchcan and hopefully the cam covers a slight vacuum to have less restrictive oil returns from the head and not have mud build up as harshly in the lines and catch can. Removed the entire front interior just shy of the dashboard itself to clean up some of the absolutely horrendous wiring, (hopefully) fix the bumpy tacho and put in LED bulbs while I was there. Also put in bulbs where there was none before, like the airbag one. I also used that chance to remove the LED rpm gauge on the steering column, which was also wired in absolute horror show fashion. Moved the 4in1 Prosport gauge from sitting in front of the OEM oil pressure gauge to the center console vents, I used a 3D printed vent piece to hold that gauge there. The HKB steering wheel boss was likely on incorrectly as I sometimes noticed the indicator reset being uneven for left vs. right. In the meantime also installed an airbag delete resistor, as one should. Installed Cube Speed premium short shifter. Feels pretty nice, hope it'll work great too when I actually get to drive. Also put on a fancy Dragon Ball shift knob, cause why not. My buddy was kind enough to weld the rust hole in the back, it was basically rusted through in the lowermost corner of the passenger side trunk area where the wheel arch, trunk panel and rear quarter all meet. Obviously there is still a lot of crustiness in various areas but as long as it's not rusted out I'll just treat and isolate the corrosion and pretend it's not there. Also had to put down a new ground wire for the rear subframe as the original one was BARELY there. Probably a bit controversial depending on who you ask about this... but I ended up just covering the crack in the side of the engine block, the one above the oil feed, with JB Weld. I used a generous amount and roughed up the whole area with a Dremel before, so I hope this will hold the coolant where it should be for the foreseeable future. Did a cam cover gasket job as the half moons were a bit leaky, and there too one could see the people who worked on this car before me were absolute tools. The same half moons were probably used like 3 times without even cleaning the old RTV off. Dremeled out the inside of the flange where the turbine housing mates onto the exhaust manifolds so the diameter matches, as the OEM exhaust manifolds are even narrower than the turbine housings as we all know. Even if this doesn't do much, I had them out anyways, so can't harm. Ideally one would port-match both the turbo and the manifold to the gasket size but I really didn't feel up to disassembling the turbine housings. Wrapped turbo outlet dumps in heat wrap band. Will do the frontpipe again as well as now the oil leak which promted me to tear apart half the engine in the first place is hopefully fixed. Fitted an ATI super damper to get rid of the worn old harmonic balancer. Surely one of the easiest and most worth to do mods. But torquing that ARP bolt to spec was a bitch without being able to lock the flywheel. Did some minor adjustments in the ECU tables to change some things I didn't like, like the launch control that was ALWAYS active. Treated rusty spots and surface corrosion on places I could get to and on many spots under the car, not pretty or ideal but good enough for now. Removed the N1 rear spats and the carbon surrounding for the tailpipe to put them back on with new adhesive as the old one was lifting in many spots, not pretty. Took out the passenger rear lamp housing... what do you know. Amateur work screwed me again here as they were glued in hard and removing it took a lot of force, so I broke one of the housing bolts off. And when removing the adhesive from the chassis the paint came right off too. Thankfully all the damaged area won't be visible later, but whoever did the very limited bodywork on this car needs to have their limbs chopped off piece by piece.   Quite a list if I do say so myself, but a lot of time was spent just discovering new shit that is wrong with the car and finding a solution or parts to fix it. My last problem that I now have the headache of dealing with is that the exhaust studs on the turbo outlets are M10x1.25 threaded, but the previous owner already put on regular M10 nuts so the threads are... weird. I only found this out the hard way. So now I will just try if I can in any way fit the front pipe regardless, if not I'll have to redo the studs with the turbos installed. Lesson learned for the future: Redo ALL studs you put your hands on, especially if they are old and the previous owners were inept maniacs. Thanks for reading if you did, will update when the engine runs again. Hope nothing breaks or leaks and I can do a test drive.
