RH9 is no where near Canberra or actually has a motor in it  :)
What does this RH9 actually look like type, colour, etc.
Second JUN 2.7L's comment;so,who's got an R34 GT-R that looks like RH9 then?
https://www.sau.com.au/forums/topic/30059-spotted/page/240/#findComment-1732944
actually i do....
the car in question is a purple/blue kamelion painted r34. 18 or 19" works (meisters??... the multi double spoked ones with a bit of dish). looked stock-ish (other than the paint/wheels/exh of course). i saw it at work maybe 1-2 weeks ago on a sat or sunday... i was late from my lunch break at work that day cos i stopped outside to check it out! hotness thats for sure!
i thought it was rh9 at the time but i also heard that the purple beast was not exactly driving... :D
forgot to post it spotted and i'd left my phone (camera) inside the office so i didn't get a snap. when i ducked out later on that day, it'd gone...!
wonder if hes a "silent" sau member... seems there's been a few of them! :) *points finger at nick!!*
d
https://www.sau.com.au/forums/topic/30059-spotted/page/240/#findComment-1732980
So who's got the auto R33 with chromies and paint like ford acid rush that was doing laps of Civic tonight and thought that 1st gear kick down is sik cos they didn't want an R31 making sneezing noises like their car can? :)
https://www.sau.com.au/forums/topic/30059-spotted/page/240/#findComment-1733185
I saw that 34 about 2-3 weeks ago at a house in Gungahlin, I was staring at his GTR while he was staring at my GTR :P
Mmmmmm that car is sex!
https://www.sau.com.au/forums/topic/30059-spotted/page/240/#findComment-1733874
spotted this morning a maroon 32 gts-t on the way to work, he didnt seem to interested....
and a maroon series 1 r33 gts-t with an exhaust and similar looking wheels to mine, parked across the road from the shell servo at deakin. looked very nice....
https://www.sau.com.au/forums/topic/30059-spotted/page/240/#findComment-1733886
Ahh damnit, spotted again without me knowing. sorry dude, must've been in a world of my own this morning.
NAth
https://www.sau.com.au/forums/topic/30059-spotted/page/240/#findComment-1735762
i'll post a picture of it later... it looked heaps liek rh9 but again i heard that it was off the road, hmmm oh well we'll find out later whose it is.
Dayne
https://www.sau.com.au/forums/topic/30059-spotted/page/240/#findComment-1736028
spotted the most horific sight in the world.
silver 33 gtr. te37 volks in that gray purple colour (like bob mitchell's car). completely totalled. front bar gone. boot/lights etc gone. big hole in the passenger side quarter. big ap racing brakes. big a/m fmic. i completely freaked when i saw it!!!!
d
https://www.sau.com.au/forums/topic/30059-spotted/page/240/#findComment-1736037
damn that sucks big time :D
d
https://www.sau.com.au/forums/topic/30059-spotted/page/240/#findComment-1736922
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
