spotted skyline tailights in the distance tonight going over Athllon Drive at about midnight, they turned left onto Drakeford. I think it was a dark coloured R32......tried to catch up but was stuck behind a w@nker in an Audi..
https://www.sau.com.au/forums/topic/30059-spotted/page/250/#findComment-1777054
silver r34 nice and clean. Pulling into a shitty servo near my place, plus a gunmetal 32 on ginninderra drive, that got majourly cut off, then 2 mins down the road i got majouly cut off by some of old f**ks in a commiewhore, complete front lock up. AAAAAAAAAARERRRRRRRRRRR!!!!!!!!! I was half a sleep and it scared the shit out of me.
https://www.sau.com.au/forums/topic/30059-spotted/page/250/#findComment-1777172
spotted mick and mark in their silos doing what i presume was a formal run?
Yeah, we did a run for Karabar high school
Erica was there too in the Forester, about 3 or 4 mins behind us
Few other 33s as well, and no GT-R's strangely
https://www.sau.com.au/forums/topic/30059-spotted/page/250/#findComment-1777195
spotted some many skylines in the past two weeks to many to mention lets see
rach at the st claires
IB6UB9 at the car wash consitantly
White R32 on wednesday night on the way to tuggers formal
also with the gtr p148rt i think thats it
bugger know I've seen so many more just can't think right now
p.s: Spotted Nismo nealy every day crazy bastard
https://www.sau.com.au/forums/topic/30059-spotted/page/250/#findComment-1778764
spotted a ferrari or lambo or SOMETHING LIKE THAT (have spend ages on google trying to find out what it was but have no idea) on Northbourne about 6.30pm
all i know is that it was red, it had kinda 'sharp' lines (not rounded), it had twin exhausts coming out of each side, a big rear wing, and a badge on each side of the back and the one on the left was kinda running writing and 2 lines.
and it was bloody loud (even just idling).
https://www.sau.com.au/forums/topic/30059-spotted/page/250/#findComment-1780854
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
