heh, you always spot that one,
spotted heaps of lines the past couple of days, waved to most and they returned, no one familiar to me though, amazing how man lines you see when you drive around in the day instead of working
https://www.sau.com.au/forums/topic/30059-spotted/page/257/#findComment-1813936
Spotted my car's doorhandle laying on the ground next to it completely f**ked when I came out of work. Some little f**ker hacked it out with scissors, leaving me a nice, big, bent, scratched hole where the handle should be. Thank f**k my alarm sent the bastard running before they could get anything from the car.
f**kf**kf**kf**k >>_+[iPDFSGUO;w{hGF
Just what I wanted for christmas, a repair bill courtesy of some stupid arsehole.
Edited by Sauce
https://www.sau.com.au/forums/topic/30059-spotted/page/257/#findComment-1814580
Spotted yesterday a black R33 with NSW plates and big FMIC near Bunnings in tuggers. He waved at me as i stared but didnt get a chance to wave back. Waited for him to catch up and tried to wave but he didn't see. Anyways, IMMACULATE looking car, i was in awe! I want my baby to look like that!
https://www.sau.com.au/forums/topic/30059-spotted/page/257/#findComment-1814816
How many rear wheel kilowatts does your car have Andrew??? :(
less than yours, im running more boost too :(:(
Sauce, that really sux dude, what sort of person does that sort of shit? spesh at this time of the year :)
https://www.sau.com.au/forums/topic/30059-spotted/page/257/#findComment-1814890
Spotted about 25 minutes ago:South bound white R33 GTS-T on Lanyon Drive-A.C.T. plates mounted on the lefthand of the 'bar,FMIC,that short low boot extension type wing driving like a bonehead. Weaving through the traffic,he nearly sideswiped the GT-R before ripping through the Jerra' roundabout...Christmas day,double demerit points,every tourist and his mutt driving along in la-la land...and someone wants to play "boost-hero racer" with the rolling chicanes?!? If this happens to be one that frequents this forum,or if someone knows the owner,drop me a P.M.;I'd really like a "quiet word" in your ear...
https://www.sau.com.au/forums/topic/30059-spotted/page/257/#findComment-1815241
Boost-hero racer!!! HAHAHAHAHA! :lol:
great way to put it jayce! some people arent too smart are they......
Sauce, sorry to hear and see that man. what a pain in the arse......
https://www.sau.com.au/forums/topic/30059-spotted/page/257/#findComment-1815741
    • How much have you lowered?  I had 350Z springs in the rear and was able to pull the camber into factory spec with the factory arms on the rear, obviously the front ran negative camber as it isn't adjustable, but rotating the wheels regularly evened out the wear.
    • Either the installer needs to come back, you need an auto electrician, or you need to learn automotive electricals yourself.   First step Id look at is where that big thing came out of, is there still things unplugged at that location? Maybe they just forgot to put a relay in or something?
    • Well, this is probably where a wiring diagram and a multimeter come into play.
    • I can say to anyone thats doing this; having done a number of R clusters; just be careful if its an unknown cluster.  It takes a bit of force to pull up; but if it feels excessive then its probably stuck. I've had this and pulled the entire hair spring out; and I can tell you; its not easy getting the correct spring replacement with the correct inner diameter and winding. In my case someone had used some sort of adhesive to stick it to the spindle and it pulled the whole spindle out; which the force seperated the hairspring from the spindal and caused it to deform.  You may have to clean it (IPA); or in my case if i'd known i should have used some sort of solvent on it.  Also check out Cruizin Central on eBay. He does all sorts of dials; and you can email him with any custom designs you want. So if you want like certain logos etc...he'll send you a mock of what it will look like then you accept the order and he'll take care of the rest. Fantastic dials and he can do basically any design you want.
    • Have you confirmed its the actual axles? Also the wheel bearings that mount on the hubs to hold the axles wear out. I replaced mine as they got play in them. It sorted my play issue.
