spotted me getting a spanking from a zx-6 on the way to work this morning. he was geeing me up for about 2km's, popping mono's and asking the question. i was hoping that he'd fall off if he hit it hard enough!!!! HA! also saw a nice black s13 with chromies and a monster tacho, which i munched after he saw me loose to the bike and tried the same thing!!!! HAHAHA!
https://www.sau.com.au/forums/topic/30059-spotted/page/261/#findComment-1837711
Not really a spotted, but my limey green gal has just been sold!!! I had one last drive in her yesterday trying to get a blue slip (long story) but all to no avail, because as soon as the idiot at pharleys (dont bother going to him) wouldnt touch it without an engineer certificate. This was not due to the a/market turbo, but the FMIC and pod. Sounds like it is new legislation in NSW. Crazy 'cos he didnt give a toss about anything mechanical about the soarer in april. Mind you, no-one else that we contacted would do it without a certificate either. Oh well, she has gone to a loving home, which is what I really wanted. (sigh.....)
https://www.sau.com.au/forums/topic/30059-spotted/page/261/#findComment-1838376
Spotted so many lines out last night - Nathr32 gave way got one back:) R33 GTR gave wave, said hello, was returned:) And also had a chat to Mr.Italy, If your wondering what was wrong, was a crack in a T peice off my block... Should be fixed today:)
Dayne
https://www.sau.com.au/forums/topic/30059-spotted/page/261/#findComment-1840306
spotted lots of lines last night. sick 34 gtr. couple of 33 r's. stirlo and the yellow peril. and yeah that pimped cima. they aren't purple flames - its harlequin/effects/flip stuff... the owner is from perth or something - from xspeed from memory - and he's been in canberra a few months now. tis a sick car tho.
and yes. racialnats are here
d
https://www.sau.com.au/forums/topic/30059-spotted/page/261/#findComment-1840956
spotted all the same, don't wanna sound repetitive but stirlo, nath, and a few others
went to maccas for dinner and saw a security guard there, thought WTF and had a chat to him. same as what andy said, busloads of lebanese blokes coming down from sydney, and messages being spread about fights.
shitheads.
https://www.sau.com.au/forums/topic/30059-spotted/page/261/#findComment-1840995
Spotted Jayce and I deciding on which way to beat up Mick after seeing him with the neons on in Braddon :D
I'm a big fan of neons.....but dude! we could see the tubes, which ruined the effect! just hide those tubes and it'll look sweet ^_^
https://www.sau.com.au/forums/topic/30059-spotted/page/261/#findComment-1845165
    • Lets say I wanted to buy this, specifically for this purpose. How do I actually perform the function. Can I still buy a Consult-1? Am I about to be burned by the fact my car is a 2000 model Series 2 R34 and thus will be some stupid other system? Do I just need this -> https://obd2australia.com.au/product/nissan-consult-14-pin-to-usb-ddl-diagnostic-interface-with-ftdi-ft232r-chip/ And with what software?
    • That's probably OK. That's a face to face compression joint between two surfaces with the clamping load provided by those bolts. So.... it's unlikely that the bolts will end up feeling that load in shear, unless the clamping surfaces are not large enough, bolts not got enough tension on them, etc etc to prevent the two faces from moving wrt each other. Which... I would hope the designers have considered, seeing as it's probably one of the most important things the upright has to do apart from resist collapsing in its own right. But yes, it would definitely be worth asking them what their safety factor on that part of the design was. I tend to think that the casting, being a casting, is not necessarily the strongest bit of material in the world. It's about an inch square, and when you think about the loads that are being put into it, you have to wonder what safety factor the Nissan boys (and every other OEM engineer who has designed all the millions of other uprights that look essentially the same) used to account for defective casting, aging, severe impacts on the wheel, etc etc.
    • Those bolts would be orders of magnitude stronger that cast aluminium though.  And its mainly clamping force, not shear they are dealing with?
    • Except all that twisting force that is breaking a cast piece, appears to be going through 4 bolts in the picture Johnny posted of the BryPar one...
    • The smart approach is to use the gearbox loom from the manual car. Makes it a lot easier - just plugs into the switches on the box and plugs into the main loom up near the fusebox. Then you only need to deal with bypassing the inhibit switch. The other approach requires you to use the wiring diagram to identify those wires by colour and location, perhaps even indulging in a little multimeter action to trace them end to end to make sure, and then.... you will have the answers you need. The R34 wiring diagram is available on-line (no, I do not have a link to it myself - I would have to do a search if I wasn't able to go to the copy I have at home).
