rebuild ??? i thought it had already had a rebuild the fact you were running that monstor turbo or did you just want to freshen it up ???
SPOTTED DAD picking up SHY32 finaly from the rebuild ;)
He has to run it in so if you guys need a cruise this friday then let me or him know.
Cheers Dan
https://www.sau.com.au/forums/topic/30059-spotted/page/279/#findComment-1982417
SPOTTED DAD picking up SHY32 finaly from the rebuild :)
Cheers Dan
Welcome back! Nice to have another big hitter prowling the streets again!
https://www.sau.com.au/forums/topic/30059-spotted/page/279/#findComment-1984009
Spotted: absolutely zero imports in the Sydney CBD in the first 24 hours I've been here..... (Yes I'm bored. I'm sitting in the Sydney Masonic Centre with absolutely nothing to do and taking advantage of some free wireless broadband)
I did however se a couple of current model M3's and a Ferrari 360 last nite
https://www.sau.com.au/forums/topic/30059-spotted/page/279/#findComment-1984289
lucky bastard. i wish i had an all expenses paid trip..... :D
https://www.sau.com.au/forums/topic/30059-spotted/page/279/#findComment-1984484
Don't worry Luke, I'd rather be at home.
It's nice to come here for a couple of days, but I so couldn't live here.
Spotted import number 1, and yes it's a Skyline, black R34 GT-t on Castlereigh Street bodykit and what looked very similar to Nismo LM wheels
https://www.sau.com.au/forums/topic/30059-spotted/page/279/#findComment-1985507
explain?
Oh... work flew me to Sydney on Monday until tomorrow night, I'm helping with some Building Code of Australia energy efficiency seminars that they're doing in all the capital cities.
I'd like to go to the Brisbane one but I doubt I'll be going.
Anyway, I've just been wandering around the city with an old school friend, we've seen....
A white R34 GT-t
A white R33 GTS-25t
A gunmetal grey R32 GT-R
A white R33 GT-R with the plates "GDZILA" parked outside my hotel on Castlereigh street
A black Pulsar GTi-R
A Sydney ghost tours HEARSE (mad!) on George St
A black Ferrari 360 Spyder convertible on Pitt St MMMMM BITCH
A red 360 Modena that gave it a hit past me on George St... OMFG THE NOISE
A red 360 Spyder (They really do like them 360's here....)
A white S15 convertible (Sexy, SEXY. I didn't even know they existed, yes I did check to see if it was an S13 with a front/rear end conversion, no it was a proper S15.)
A black 997 911 Carrera 4
A Bentley Continental GT on Oxford St
And this really old 1940's lowrider that when the guy gave it a rev, belched flame out it's sidepipes :woot:
And that's just off the top of my head
https://www.sau.com.au/forums/topic/30059-spotted/page/279/#findComment-1986030
spotted *can't call him by his correct name cause that'd take effort* AGAIN! possibly on your way home from the tuggerz apartments...? well anywho, is that ur main point of business...?
Yes.
and FFS my name is Andrew, i've told you before.
https://www.sau.com.au/forums/topic/30059-spotted/page/279/#findComment-1986792
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
