rebuild ??? i thought it had already had a rebuild the fact you were running that monstor turbo or did you just want to freshen it up ???
SPOTTED DAD picking up SHY32 finaly from the rebuild ;)
He has to run it in so if you guys need a cruise this friday then let me or him know.
Cheers Dan
https://www.sau.com.au/forums/topic/30059-spotted/page/279/#findComment-1982417
SPOTTED DAD picking up SHY32 finaly from the rebuild :)
Cheers Dan
Welcome back! Nice to have another big hitter prowling the streets again!
https://www.sau.com.au/forums/topic/30059-spotted/page/279/#findComment-1984009
Spotted: absolutely zero imports in the Sydney CBD in the first 24 hours I've been here..... (Yes I'm bored. I'm sitting in the Sydney Masonic Centre with absolutely nothing to do and taking advantage of some free wireless broadband)
I did however se a couple of current model M3's and a Ferrari 360 last nite
https://www.sau.com.au/forums/topic/30059-spotted/page/279/#findComment-1984289
lucky bastard. i wish i had an all expenses paid trip..... :D
https://www.sau.com.au/forums/topic/30059-spotted/page/279/#findComment-1984484
Don't worry Luke, I'd rather be at home.
It's nice to come here for a couple of days, but I so couldn't live here.
Spotted import number 1, and yes it's a Skyline, black R34 GT-t on Castlereigh Street bodykit and what looked very similar to Nismo LM wheels
https://www.sau.com.au/forums/topic/30059-spotted/page/279/#findComment-1985507
explain?
Oh... work flew me to Sydney on Monday until tomorrow night, I'm helping with some Building Code of Australia energy efficiency seminars that they're doing in all the capital cities.
I'd like to go to the Brisbane one but I doubt I'll be going.
Anyway, I've just been wandering around the city with an old school friend, we've seen....
A white R34 GT-t
A white R33 GTS-25t
A gunmetal grey R32 GT-R
A white R33 GT-R with the plates "GDZILA" parked outside my hotel on Castlereigh street
A black Pulsar GTi-R
A Sydney ghost tours HEARSE (mad!) on George St
A black Ferrari 360 Spyder convertible on Pitt St MMMMM BITCH
A red 360 Modena that gave it a hit past me on George St... OMFG THE NOISE
A red 360 Spyder (They really do like them 360's here....)
A white S15 convertible (Sexy, SEXY. I didn't even know they existed, yes I did check to see if it was an S13 with a front/rear end conversion, no it was a proper S15.)
A black 997 911 Carrera 4
A Bentley Continental GT on Oxford St
And this really old 1940's lowrider that when the guy gave it a rev, belched flame out it's sidepipes :woot:
And that's just off the top of my head
https://www.sau.com.au/forums/topic/30059-spotted/page/279/#findComment-1986030
spotted *can't call him by his correct name cause that'd take effort* AGAIN! possibly on your way home from the tuggerz apartments...? well anywho, is that ur main point of business...?
Yes.
and FFS my name is Andrew, i've told you before.
https://www.sau.com.au/forums/topic/30059-spotted/page/279/#findComment-1986792
    • Ok I get you. But isn’t the butterfly intake a headache with the +T?  see this is my plan so far but please advise me into the right direction.  Nistune Ecu, 1000cc Bosch injectors, TD05 or TD06 Kinugawa turbo using stock rb25det exhuast manifold, walbro fuel pump unsure of model I think it’s 450/460, spitfire coils and sparks to suit and a R35 MAF sensor and boost sensor.    I was thinking maybe do a cheap eBay plenum $400-500 or try find a stock det neo intake. I think I’d port match it so it’s getting the full capacity but open to advice please.  Thanks
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
