Gave/got a wave/nod this morning from a guy in a silver R33 on Belco Way this morning. Couldn't tell much about the car except it had a kit and nice many spoke rims, think it had a FMIC too. I was in the other Silver R33. Wonder what was up? .... with everyone hooning around you? Looked like you were content doing 60 :yes:
That would probably be me.
Especially given this week i was more than content doing 60 everywhere. Was trying to conserve some fuel... Man these cars just werent meant to be driven slowly...
https://www.sau.com.au/forums/topic/30059-spotted/page/328/#findComment-2473064
Spotted Terminal in belconnen after work today! Nice Stagea mate! :)
yeah i saw you guys go past. i was getting in the shit from the missus, so i couldn't really start waving. man she can talk my ears off sometimes. your car looks good too.
https://www.sau.com.au/forums/topic/30059-spotted/page/328/#findComment-2478433
spotted a silver? r33 coupe near reid CIT, sped up to me and sat next to me for abit then went infront of me. I was the white sedan. was gonna follow you but had to go slow as my gf was following me (didn't know directions) just picked it up from getting a service and pod filter installed. im in love.
https://www.sau.com.au/forums/topic/30059-spotted/page/328/#findComment-2481535
Delayed spotto - gave & got a wave from a fellow in a burgundy 33 on saturday or sunday on Hindmarsh Drive, and spotto'd Chitami in Weston on Saturday night
And also Spotto's stunnd's GT-R back on the road
https://www.sau.com.au/forums/topic/30059-spotted/page/328/#findComment-2481641
Spotted Yaf28f at badminton tonight.
Cool, didn't notice any fto or skylines there last night. but pretty embarrassing as I was leaving the carpark, was tired from playing hard games and on the way out ran over a gutter.
-Michael
https://www.sau.com.au/forums/topic/30059-spotted/page/328/#findComment-2484552
We spotted u 2... funni i was passenger in the burgundy 33 on sunday when we waved at u and yes that was me on sat night.. sorry i didnt wave! will do next time!
https://www.sau.com.au/forums/topic/30059-spotted/page/328/#findComment-2486244
    • Well, this is probably where a wiring diagram and a multimeter come into play.
    • I can say to anyone thats doing this; having done a number of R clusters; just be careful if its an unknown cluster.  It takes a bit of force to pull up; but if it feels excessive then its probably stuck. I've had this and pulled the entire hair spring out; and I can tell you; its not easy getting the correct spring replacement with the correct inner diameter and winding. In my case someone had used some sort of adhesive to stick it to the spindle and it pulled the whole spindle out; which the force seperated the hairspring from the spindal and caused it to deform.  You may have to clean it (IPA); or in my case if i'd known i should have used some sort of solvent on it.  Also check out Cruizin Central on eBay. He does all sorts of dials; and you can email him with any custom designs you want. So if you want like certain logos etc...he'll send you a mock of what it will look like then you accept the order and he'll take care of the rest. Fantastic dials and he can do basically any design you want.
    • Have you confirmed its the actual axles? Also the wheel bearings that mount on the hubs to hold the axles wear out. I replaced mine as they got play in them. It sorted my play issue.
    • Ive converted a few clusters for the R33 with 320km/h dials. On the back there are some pads which can be bridged or unbridged (using solder or wick braid) to calibrate it. There is one bridge which is for MPH <> KPH; and there are combinations of bridges to offset it. There is probably a diagram  For example; this is my conversion for a 180km/h dial to a 320km/h dial (I put custom GT-R dials on it with the GTS25t layout) If you have J2 soldered (assuming the S clusters have a similar config to the R clusters); you may need to remove that solder
    • Back on topic 😉, these are some of the notable pages from the booklets that are supplied with each weekly parts update. I never knew the BNR32 test mule car had an S13 Silvia front end... *Edit: On closer inspection the test car still had the R32 body, but only the front end had Silvia panels etc.
