spotted a silver 33 with a carbon bonnet, had a bit of primer up one side too, might have had a widebody conversion done or something.
spotted a white 4dr R33 GTS & a black R32 GTST with huge FMIC on the hume/federal driving back to canberra today
https://www.sau.com.au/forums/topic/30059-spotted/page/337/#findComment-2546535
just spotted a V12 Vanquish, YES!!! A VANQUISH!, going towards civic along commonwealth ave at around 11.30am.... i want one!!!
Was it dark green? i saw what i thought was one last night along belconnen way. maybe it was indeed...
https://www.sau.com.au/forums/topic/30059-spotted/page/337/#findComment-2549096
I am dissapointed I have had my skyline now for 2 weeks and would of thought that someone on here would of spotted me but still i have not been spotted come on guys some one spot me. i drive a white r33 gts-t that sits super low and has 18" chrome rims with a front mount and modified series 1.5 front bar :( and i spend alot of time around civic. my display pic is my car.
https://www.sau.com.au/forums/topic/30059-spotted/page/337/#findComment-2550106
Spotted...
two tone 33 with multispoke rims at Chisholm shops around 1pm..
black series 1 33.. and the roundabout of Athlon and Sulwood.. either that thing was non turbo... or something wrong.
white 4dr 32 in Gowrie, wine red 33 with front bar somewhere.
another black 33 series 1 in isabella round 5pm..
and prob more.. few skylines out today.
Edited by SkyGTRline
https://www.sau.com.au/forums/topic/30059-spotted/page/337/#findComment-2550152
Spotted Sauce the other day, can't miss that fro. I too spotted that red 34GT-T with GT wing at J-Racing today when I dropped in. Looks mint!!
Sorry Mick I didn't see you but yeah I was cruising around Fyshwick this arvo.
https://www.sau.com.au/forums/topic/30059-spotted/page/337/#findComment-2550335
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
