lol first spot in months mind you its been off the road for a month and will be till i can get the A/F ratio down. Yeah its been ages you have only just seen me do a drive by with carbon bonnet ill bring it to Beaus
Yah.
https://www.sau.com.au/forums/topic/30059-spotted/page/338/#findComment-2550681
Yah.
Well I'm proud I spotted it! I did think of you when i saw it but im like na cant be shauns!! you better! been a while!
Edited by skyline_babe5
https://www.sau.com.au/forums/topic/30059-spotted/page/338/#findComment-2550691
spotted some guys driving on Copeland Drive.. I think it was on sunday (??), maybe going on a cruise or something.. there was an R33 first with a cf bonnet and then about 5 other cars... rex, silvias n others..
i just waved at everyone lol
https://www.sau.com.au/forums/topic/30059-spotted/page/338/#findComment-2551272
spotted the silver R33 GTR with carbon bonnet again last night in civic. has a sunroof. definately has had some sort of work done to the rear guards as they were both bogged up/prepped for painting. sounded tough
https://www.sau.com.au/forums/topic/30059-spotted/page/338/#findComment-2552296
I spotted a silver R33 with a carbon fibre bonnet heading into Weston Creek about an hour ago. I wasn't sure if it was a GT-R, it had widened rear guards, but they were in primer.....
if it was the one with the fake GTR badge, it might be the one that was @ Inline, an asian guy owns it, and i think its around the 300rwkw mark with a GT3540.. not too sure though..
https://www.sau.com.au/forums/topic/30059-spotted/page/338/#findComment-2554536
    • Ok guys thank you very much. GCG highflow it is then 🙂
    • forgot to mention that when it does this it does not kill the engine, but I have not kept the pedal down long enough to let it, as I see no reason to beat up on it as its got to be something simple, small and dumb causing this.  And as soon as I let off pedal, the engine returns to its normal super smooth operation and rpms re-stabilize quickly, once below 4k.
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
