Had good day today.
Black and a white 32 in Erindale.. doin' something to the rear left wheel.
I pulled over and asked if they were ok, but I couldn't make out what he was saying at times. haha.. so I drove off.
And a maroon 32 heading out of Lanyon.. I gave a small fingerwave from inside coz I was lazy.
https://www.sau.com.au/forums/topic/30059-spotted/page/380/#findComment-2897547
Spotted Datman (r33 owner) at GasTune today around 1pm. Great to meet you and have a quick chat, sorry if I was a bit out of it, having a bit of an average day at work, and trying to get a stalling problem fixed as well on the car. So I was in a bit of a hurry.
https://www.sau.com.au/forums/topic/30059-spotted/page/380/#findComment-2902174
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
