spotted what looked to be low200 pulled over by coppers the other night sorta up from the woden hospital if i remember correctly
Yep, that was me.
Fella was quite nice which was good, told me off for my suspension being too stiff and my front bar was wobbling a bit. Let me off without defect which was REALLY good as im trying to sell it.
https://www.sau.com.au/forums/topic/30059-spotted/page/390/#findComment-2956160
Lol, you never would. As most know I don't have the 33 anymore and I was in a friends car at the time. So even if you did know my KIA you wouldn't have seen me....and even if you did look at every driver as they passed by you wouldn't have seen me as I was riding shotgun.... No surprise you didn't see me really, lol.
https://www.sau.com.au/forums/topic/30059-spotted/page/390/#findComment-2957980
I saw a monster amount of skyhlnes on the way to footy training drakeford drv around 625pm
A white 33 with a pink tempe sticker on wind screen.. a dark 32 with SA rego.. and another white 33 intersecting it heading into tuggers.. ALL at the same set of lights.
https://www.sau.com.au/forums/topic/30059-spotted/page/390/#findComment-2958065
spotted a white r33 in fyshwick across from that harly shop it had red plates
That car is there every day. I looked under it one time to reference the R33 drive shafts (was doing a CV conversion for the datto), dont think he saw me :P.
https://www.sau.com.au/forums/topic/30059-spotted/page/390/#findComment-2962102
oh yea i forgot to say i am pretty sure that i spotted leashy when i was playing baseball on Sunday at Curtin around 12 - 1pm
Name's Leshy, get it right... crikey.
That would have been my missus going to work at the hospital, as she's been driving my Stagea around for the past 2 months while Toyota do a really efficient and cost-effective repair job on her Corolla. I'm now cruising around in a crappy red VL commodore, so don't bother trying to spot me :ninja:
https://www.sau.com.au/forums/topic/30059-spotted/page/390/#findComment-2962625
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
    • Carrying out some engine due diligence before my first drive in a 260RS that has been in storage for 10+ years, and found two lines that are susposed to be plumbed into the boost control solenoid. One of the lines (the wastegate boost supply line) to actuate the gates, had a bolt in one end blocking it. The other line (main boost signal line) from the very rear of the intake manifold (RB26DETT) and runs up to the boost controller had this pill in the end of it as seen in photos. Other than the obvious (T28 Ceramic turbos might well be cooked)  Can anyone shed any light on if there is any validity at all with this mod, bleeding a constant fixed rate of manifold boost pressure off through this 3mm hole?  Is it deliberate?  Was this a 90s Jap mod done to RB26's? Or has someone just fitted this without any idea of what happens to ceramic T28s if they are not gate controlled?
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
