Taxi drivers hey. Driving down Northbourne last night a copper pulled up beside me, gave me a very weird look, then proceded to CUT ME OFF!.... he then sped off, merged into a turning lane without indicating, then pull out of it and kept going straight. I should have gotten his licence plate number and reported him, but I was too busy swearing at him.
Spotted a nice Blue R33 GTST in civic and a Maroon one in Dickson, but it had ugly chrome wheels.
It must be the latest thing to do, Good Friday I was driving along Athllon Dr and a Cop nearly ran me off the road. I swear he took the clear coat off my front bar :D
Automatically went to blast him with the horn...figured i would same time and possibly money by letting it go.
(I think this shouldve gone in What ticks you off thread...cos thats what grinds my gears)
https://www.sau.com.au/forums/topic/30059-spotted/page/403/#findComment-3054931
Thats awesome Simmo.
Got an ETA on its return?
thanks man, not sure when itll be back yet, hopefully not too long i hope :whistling: . just steering it onto the back of the truck and having it move again has made me more impatient though heh.
spent quite a wwhile drooling over [YES-32R] at trojan, also spotted MKDR33 but ive been beaten to the spotted thread again hehe, good to meet you too man ;)
https://www.sau.com.au/forums/topic/30059-spotted/page/403/#findComment-3055620
white four door r33 near civic yesterday.
also a black r33 with silver stripey tattoo bits in woden. i'd advise against parking next to the trolley return bays in that underground carpark - the trolleys don't have brakes, and the chaps collecting them don't care what stops them!
Edited by sigsputnik
https://www.sau.com.au/forums/topic/30059-spotted/page/403/#findComment-3062590
nice town you got here...
spotted a burgandy R33 last night at about 11ish on commonwealth av. I was in my dad's black ceffie.
passing thru canberra from syd. decided to stay a few days in Kingston.
so where you all at? there's so few imports here... and everyone drives riced up celica's??? wtf.
https://www.sau.com.au/forums/topic/30059-spotted/page/403/#findComment-3063324
You must not be looking to hard... i reckon i see more imports in Canberra than when i am getting around Sydney and Melbourne. A lot of the skylines are further out south. Northside well except for passing through to get out of Canberra there is no need to go there :P
https://www.sau.com.au/forums/topic/30059-spotted/page/403/#findComment-3063618
Spotted wingless silver R33 on Parks way 8.50 lastnight followed you from black mountain to Kings av bridge.
Aaahhhh that was you up my bum :) I'm ashamed to say but I actually thought your car was an old porsche, looking through my rearview mirror :( I'll be sure to wave next time I see ya
Also spotted R34-GTT last night on Hindmarsh Drive. Hey Mladz, did you go to the movies? saw you pull out of the carpark behind me at hoyts
Edited by R33Driftr
https://www.sau.com.au/forums/topic/30059-spotted/page/403/#findComment-3063925
    • Wheel alignment immediately. Not "when I get around to it". And further to what Duncan said - you cannot just put camber arms on and shorten them. You will introduce bump steer far in excess of what the car had with stock arms. You need adjustable tension arms and they need to be shortened also. The simplest approach is to shorten them the same % as the stock ones. This will not be correct or optimal, but it will be better than any other guess. The correct way to set the lengths of both arms is to use a properly built/set up bump steer gauge and trial and error the adjustments until you hit the camber you need and want and have minimum bump steer in the range of motion that the wheel is expected to travel. And what Duncan said about toe is also very true. And you cannot change the camber arm without also affecting toe. So when you have adjustable arms on the back of a Skyline, the car either needs to go to a talented wheel aligner (not your local tyre shop dropout), or you need to be able to do this stuff yourself at home. Guess which approach I have taken? I have built my own gear for camber, toe and bump steer measurement and I do all this on the flattest bit of concrete I have, with some shims under the tyres on one side to level the car.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
    • I know I have to get a wheel alignment but until then I just need to bring the rear tyres in a bit they're wearing to the belt on the inside and brand new on the outside edge. I did shorten the arms a bit but got it wrong now after a few klms the Slip and VDC lights come on. I'd just like to get it to a point where I can drive for another week or two before getting an alignment. I've had to pay a lot of other stuff recently so doing it myself is my only option
    • You just need a wheel alignment after, so just set them to the same as current and drive to the shop. As there are 2 upper links it may also be worth adding adjustable upper front links at the same time; these reduce bump steer when you move the camber (note that setting those correctly takes a lot longer as you have to recheck the camber at each length of the toe arm, through a range of movement, so you could just ignore that unless the handling becomes unpredictable)
