yesterday i spotted:
1. Bullet32 going home along Canberra Ave around 5.40pm ish. gave a wave/got a wave (finally! :thumbsup:).
2. shortly after a blueish purpleish r32 GTR heading the same direction.
3. a gun metal r32 gts-t parked at the swinger hill shops at around 6pm. i heard you leave, car sounded great. RB20's give 1 of the best exhaust notes ever...
last monday i spotted a white r33 GTR leaving fyshwick in the early afternoon. gave it a squirt and was pretty quick. looked sweet too....
https://www.sau.com.au/forums/topic/30059-spotted/page/434/#findComment-3332777
Drove to Sydney to pickup my GTR wing and boot (gen-u-wine :)) and spotted two 34 GTRs (1 blue (pulled into right lane to let him merge onto Hume Hwy and he absolutely flew past me, he would of been going around 200km) and the other was black) and 1 black GTT.
Good days spotting, cant complain about seeing 2 34 GTRs :)
https://www.sau.com.au/forums/topic/30059-spotted/page/434/#findComment-3335149
spotted a BMW 850I V12 :P i thought it looked pretty old. Turns out they were released in the late 80's for get this... around $220,000... now I am no mathematician but wouldn’t $220,000 in the 80’s would be a S^#t load of money back then for a car... now a days it's probably not seen as a stupid amount for that sort of car but i mean back then that would almost be bugatti veyron money :closedeyes: ... anyways they can now be had for around 30 - 40K :no:
http://yahoo.drive.com.au/Editorial/Articl...?ArticleID=9682
https://www.sau.com.au/forums/topic/30059-spotted/page/434/#findComment-3345585
I dont know if you know Leigh but I used to work for BMW and we had all sorts of problems with the 850i's... They werent the best built beemer ever thats for sure.
They also didnt sell very many because of the price tag, they were a BIG flop for BMW and I think they lost a lot money out of it too.
Nice cars though and they go pretty good (even though they weigh 2 tonnes). :closedeyes:
Edited by Bullet32
https://www.sau.com.au/forums/topic/30059-spotted/page/434/#findComment-3345704
No I never had the pleasure of even seeing an M1, I dont think that there are any in Australia...
I did get to drive plenty of M3 and M5's though.
By the way, that pic of the red 850i you have there is the "Alpina" model, they were even MORE expensive.
Edited by Bullet32
https://www.sau.com.au/forums/topic/30059-spotted/page/434/#findComment-3345773
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
    • A bit late but A disk S13P fit over stock R32 GTR brakes, usually A disk front, O disk rear works.
    • Or, the height of the release bearing is not correct for your combo. Start with the bleeding and checking the slave moves throughout its range when you press the pedal (2 person required), but it is possible for the height to be internally wrong too (box back off to measure.
    • Yes, there's quite a few things that can go wrong during a clutch install. Very unlikely. I have a similar clutch. They (ACS) make good gear. No, it is not normal. It is possible that you just need to bleed the clutch slave. But the new clutch will also have a more aggressive actuation force/pressure, and so your old slave cylinder might be a bit leaky or otherwise compromised, and not up to the extra force required. Or the master cylinder, same.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
