Spotted a nice looking R32 GTR "GTRCHIK" tonight down the parkway.
Do we have a chick with a modded GTR in Canberra?
That would have been me :D
Yes you do have a chick with a modded GTR in Canberra hehe. It is a V-Spec II and has the Trust bodykit. I imported it in October 2006, have been working on it in WA but only got it brought to Canberra when I moved back from Perth (alas the WA number plates).
Edited by GTRChik
https://www.sau.com.au/forums/topic/30059-spotted/page/485/#findComment-3916309
well I drove around heaps today and all I saw was a black series1 R33 turning out of Fyshwick onto Dairy Flat, paint looked very clean and shiny, had aftermarket rims.
And a silver R33 GTR on Pirie Street Fyshwick.
both about 1.30pm
https://www.sau.com.au/forums/topic/30059-spotted/page/485/#findComment-3925032
Maroon 33 S1 this morning in Fyshwick with blue plates resembling SKI...
Black 32 in Civic heading towards Canberra Avenue - I was the guy in the Nissan jacket.
Me accidentally p1ssing off a gold Forester this morning... oops :P Hope it wasn't Leech, I'm sure I'll find out soon if it was.
https://www.sau.com.au/forums/topic/30059-spotted/page/485/#findComment-3931218
    • New CAS just turned up from NZ Wiring. Looks like a nice bit of gear.  So, yeah. Triggered, bro. Realised I may as well do the cam belt while mucking about with it so will order one of them.
