Time to rub it in....
Spotted 2 R35 GTRs at ESP today. Pics will be up shortly. The white one went on the dyno and I was lucky enough to go for a ride in the pink donut king one.... OMG words can't describe the awesomeness!!! :laugh:
Whaaa??? How did you get to go for a ride in the donut king one?! Im so jealous!!! :merli:
https://www.sau.com.au/forums/topic/30059-spotted/page/506/#findComment-4162741
Yeah but there was one nice BMW there........white with helmets on the roof
Oh! I didn't cya there! :merli: Only walked around for about 15 minutes
Edit: Spotted - me nearly being run over by a P plater in front of the NCC!! Aiee... he wasn't paying attention, locked it up and only stopped 2m short! Farrrrrk.
Edited by sl33py
https://www.sau.com.au/forums/topic/30059-spotted/page/506/#findComment-4162834
I saw 4 skylines on the way home from work today,i followed a silver 33 from my driveway at work, a black 32 gtr with a carbon bonnet heading out of fyshwick, a maroon 32 heading up erindale drive who beeped at me(sorry i didnt wave i wasnt sure if you were giving me the finger or waving,if you were giving me the finger disregard my apology lol) and finally a white 33 gtr heading up erindale drive about a minute after the maroon one, very busy day!
https://www.sau.com.au/forums/topic/30059-spotted/page/506/#findComment-4163399
I drive to and from fyswick monday to friday at 0700 and home at about 5 ish I wave to every skyline i see and i dont get any respons i guess people do not know what a DR30 rsx looks like I now have a black bonnet and a black rear wing the rest of the car is white and I usually drive on the speed limit so if your going slow its probably me in front not that the old girl is slow it is the fact there is no traction in the first three gears. so what color is your skyline
https://www.sau.com.au/forums/topic/30059-spotted/page/506/#findComment-4163679
its a black 32 gtr with a sau sticker on the back window,i havent seen yours around, where abouts do you work in fyshwick?
https://www.sau.com.au/forums/topic/30059-spotted/page/506/#findComment-4163876
haha nice work Kat... a bit of sweet talking works wonders hey! :D :D
my friend, the lovely Ms Kel on these forums is driving it tomorrow... and not just round the block... from Syd to Melbs! omg how cool would that be!
https://www.sau.com.au/forums/topic/30059-spotted/page/506/#findComment-4164316
I work down near the fyswick markets in a metal fabrication shop Its called mag welding the driveway is opposite the salvo's up in the back of the complex
https://www.sau.com.au/forums/topic/30059-spotted/page/506/#findComment-4166191
Thats a nice smooth curve Gus, it must have pretty linear delivery.
Looks like its running a bit rich at high revs (safer than running lean though) and by the looks of the top of the curve you might need to re-gap your spark plugs down to .8mm cos it looks like its blowing out the spark at peak power.
https://www.sau.com.au/forums/topic/30059-spotted/page/506/#findComment-4167841
only mods are exhaust, pod, and ed said it was running around 10 psi (no bleed valve )
the blue line was first...running rich as fark....the second was with a new o2 sensor...runs heaps better now. was ridiculous how rich it was running down low.
only problem was trying to find a new ecu now to give it a tune...ed told me about this nistune thing but i duno...dont want something only 1 tuner can do...would much rather a power fc...but ha trying to find one of them.
unjfortunately the exhaust temp light still comes when its hot on which is annoying...need to take it back to ed and see if its something else thats faulty. makes it non fun to drive.
https://www.sau.com.au/forums/topic/30059-spotted/page/506/#findComment-4168705
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
    • I know I have to get a wheel alignment but until then I just need to bring the rear tyres in a bit they're wearing to the belt on the inside and brand new on the outside edge. I did shorten the arms a bit but got it wrong now after a few klms the Slip and VDC lights come on. I'd just like to get it to a point where I can drive for another week or two before getting an alignment. I've had to pay a lot of other stuff recently so doing it myself is my only option
    • You just need a wheel alignment after, so just set them to the same as current and drive to the shop. As there are 2 upper links it may also be worth adding adjustable upper front links at the same time; these reduce bump steer when you move the camber (note that setting those correctly takes a lot longer as you have to recheck the camber at each length of the toe arm, through a range of movement, so you could just ignore that unless the handling becomes unpredictable)
    • I got adjustable after market rear camber arm to replace the stock one's because got sick of having to buy new rear tyres every few months. Can anyone please let me know what the best adjustment length would be. I don't have the old ones anymore to get measurements. I'm guessing the stock measurement minus a few mm would do it. Please any help on replacing them would be fantastic I've watched the YouTube clips but no-one talks about how long to set the camber arm to.
    • Heh. I copied the link to the video direct, instead of the thread I mentioned. But the video is the main value content anyway. Otherwise, yes, in Europe, surely you'd be expected to buy local. Being whichever flavour of Michelin, Continental or Pirelli suits your usage model.
