or maybe she just wanted to be spanked cuz she was driving a 33 ???
Good call Gus :devil:
Curves! 33's have their own post code......... like yo mama
(jokes)
Curious tho ~ What's the ratio of girls driving 33's in comparison to 31,32,34 +35's ?
Edited by Sinista32
https://www.sau.com.au/forums/topic/30059-spotted/page/528/#findComment-4340058
Spotto'd Gus (I think) in Jerrabomberra today, and a Bayside blue R34 GT-t on Erindale Drive this arvo, and spotted Rumble in Braddon tonight, as well as a few other R33s and 2 R34 GT-R in braddon as well.
https://www.sau.com.au/forums/topic/30059-spotted/page/528/#findComment-4343277
Spotted a white R33 with black bonnet driving up Northbourne near Dickson... I was in stealth mode in the Audi :D
Also saw a whole heap of tossers driving round and some copper in an undercover white Falcon pulling over some crappy old car.
Looking forward to this crap being over and Flemington road opening again.
https://www.sau.com.au/forums/topic/30059-spotted/page/528/#findComment-4344296
Spotted Erica's GT Forrester " Mrs GT" and a whole bunch of others in Braddon. Most of the street is Domminated by parked Mustangs, a few Hot Rods and of course the Subaru wagons.
Still looking good J + E :happy:
Bayside Blue Phat 34 at QIX Fyshwick.
PS. Looked like your 31 was on the street Blueprint ?
Edited by Sinista32
https://www.sau.com.au/forums/topic/30059-spotted/page/528/#findComment-4344496
aww you didn't see my car Richard? :blink: I was only a few back from Bluprint
It was cloaked in invisibility, Did you have it switched to stealth mode again? I was probably looking at cute distraction at the time :happy: sowwy.
Edited by Sinista32
https://www.sau.com.au/forums/topic/30059-spotted/page/528/#findComment-4344941
Spotted a white 33 GTS-T last night at about 9.30 on Ballumbir Street in Civic. It had chrome rims, a black(painted, Im pretty sure) bonnet, lowered with a pretty blond in the passenger seat and a young fella steering. I think it was the same one I'd seen parked in Lonsdale Street earlier watching the 'Nats merriment. Anyone on here?
https://www.sau.com.au/forums/topic/30059-spotted/page/528/#findComment-4345043
    • I was using the wiring diagram I have So 12.74V is coming into the rear Fuel Pump relay as I measured.  When I turn the key to ON im getting 0.6V to the Fuel Pump plug; which i assume is backfeed voltage and doesnt include the 12V from ignition power.  The rear relay is working and being triggered.  From the diagram I clearly see the rear relay 80 = Rear Relay going into the Body/H loom (R-27) 27 = Fuel Pump plug going into the Body/H loom (T-20) 40 = Short Connector (R-27) I'm reading 12.74V on the blue/black wire which is the power for the Fuel Pump   From this diagram I can see the Ignition relay goes into the front and up to the ignition  2 = Fuel Pump Relay <1M> (R-27) 37 = ING Relay <1M> I started from the pump using this reference Which the way I read it (referencing Nissan wiring color codes) is: Pin Wire Color Function 1 B/P (Black/Pink) Ground 2 L/W (Blue/White)        ECU Trigger 3 SB (Sky Blue) Fuel Pump 5 L/B (Blue/Black) 12V Constant Tested SB to SB on Fuel Pump for continuity - confirmed Tested negative on Fuel Pump to 12V battery and L/B - confirmed 12V Pulled the relay putting 12V between Pin 1 & 2 and testing continuity on Pin 3 & 4 - confirmed relay   So that has me looking at this part of the circuit to understand whats happening here...and im still confused. From best I can tell; the disconnect is back to my previous diagram; between Ignition Relay and Fuel Pump Relay...which yet again; afaik is where the immobiliser should.    Thats what I was trying to explain to GTSboy; im not trying to fix it myself; yet I seem to have to get a Masters in Electrical Engineering (while im busy doing my actual job of DevOps & Cloud Engineering) somehow.  I just wanted more expert opinions; or more so that what I tested is correct and proves it to something around that area; to go back to the alarm tech (for a 3rd time) that he needs to fix it. He keeps telling me its not the alarm. He lives on the complete other side of the city so i understand not wanting to make a trip but as I said before if its the alarm it should be up to him to fix it. But he's adament its not; even though I pointed out the FP was immobilised through the original alarm. To my mind; it seems that the ECU is sending the signal; but the ignition is not getting 12V down the line.
    • Maybe also really stiffly sprung track cars. Get the inside wheel up in a corner and all the fun stops. Also me sometimes (rarely) when I have to stand on the brake to convince the diff to drive the wheel that is still on the ground when I'm trying to diagonally get over severe driveway entrance, etc.
    • I feel like I'm missing something. You had an authorised installer come out and install a new alarm. Post install the car doesn't start, and you aren't getting the installer back to fix what they did wrong?
    • So either way it is gearbox out and look what is wrong?  I know about the input shaft bearing. Even before swap/new clutch the it sounded exactly like this: So is that inout shaft bearing or the other was installed backwards?  And can some please tell me the part number for that input shaft bearing? The gearbox is small box from R34 N/A and number is FS5W71C. Thank you
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
