spotted a black (or purple) R33 at Kambah, didnt wave cos I didnt think they'd wave back and I would have felt like a tosser sitting there at the lights for ages if they didnt :D
Also to the bitch in the black Integra Type R, who was sitting up my arse (even though i was doing 90 in an 80 zone)... back the f**k off!! your car isn't cool.......and you are a f**khead. That is all.
https://www.sau.com.au/forums/topic/30059-spotted/page/535/#findComment-4386288
here are the top 10 most frequent posters in Spotted!!
1) leech_ - 570
2) Terminal - 506
3) Bluprint - 379
4) Gus- - 370
5) Shell - 353
6) Veilside R33 - 335
7) SkyGTRline - 306
8) MIVEC - 283
9) sigsputnik - 263
10) LTSJayce - 261
yes i scrolled through 533 pages and counted them all
Hi all..
been a while..
im with mick (bullet32) i havent been on here in ages.. so not sure how that works..
but, is my old skyline still bein spotted.. last i heard it got resold.. kids these days..
https://www.sau.com.au/forums/topic/30059-spotted/page/535/#findComment-4386400
spotted your FTO going the opposite way on the parkway. before spotting my indicator flapping around on the bonnet...
yer the fto has been demoted to the wife's car. Not even worth the money to sell it these days, just give it to her as a run about.
how on earth does an indicator wind up on a bonnet?
https://www.sau.com.au/forums/topic/30059-spotted/page/535/#findComment-4386714
Same - travelling up to the Drift comp in Sydney in the GTR. Driving along and next thing the indicator is flapping around on the bonnet held by the cables. WTF.
Undocumented feature to Increase airflow into the Pods??
https://www.sau.com.au/forums/topic/30059-spotted/page/535/#findComment-4386871
Spotted a white 180SX last night at the traffic lights near DFO getting ripped by a Honda CRV. Wasn't like the 180SX wasn't trying, there was a lot of noise but not much movement!
Out to lunch maybe. Should of been out to Launch :D
https://www.sau.com.au/forums/topic/30059-spotted/page/535/#findComment-4388513
    • That R31 was so cool. Only did Orange Park once. Scared the hell out of me.
    • Selling my TE37SLs since I've switched to smaller wheels.  They're for sale in Japan but it's pretty simple to send them overseas; USA excluded, since JPPost isn't sending there at the moment. Specs Front: 18x9.5j +22 5x114 Rear: 18x10j +20 5x114 Price: 320,000 JPY/ 3,285 AUD (current FX rate) Condition: a few scratches here and there, no bends, distortions or cracks.  Tires will not be included for international buyers, I'll get them dismounted before shipping. They're currently listed on yahoo auction and will be shipped in Japan with the tires if they sell here. Shipping costs to Aus: EMS (1-2 weeks): AUD 1,175 (current FX rate) Sea (2 months): AUD 460  (current FX rate)
    • The alloy coolant reservoir has a sight glass, so as long as I can see coolant in the sight glass it's GTG, as for PS, it isn't anything catastrophic if it gets low, and as it hasn't lost a drop since I have owned the car I cannot see it being an issue, even after putting the "big block" 2.5 in....LOL The only time it gets slightly messy is at oil changes, as the oil filter sits above the frame, and I need to use a plastic bottle with its bottom cut off to catch the flow when loosening the filter
    • Good on you for taking on the job, but it is a big one. Even if you have bolt on manifold and turbo, you will need: Post throttle pressure source to boost controller to wastegate (and FPR, and ECU/MAP sensor) Pre throttle pressure source to top of BOV(s) Oil feed - you can take that from the standard port in the middle of the block Oil return to block under the turbo - this is much trickier than it seems to route a decent/wide pipe past the manifold. You really can't use rubber hose because it is way too hot there, and also the oil out of the turbo core is a bit frothy so it needs to have a decent diameter Water feed - you can take that from the standard port in the rear of the block. Water return - mine runs to a T into the heater box return, just make sure you don't create a high point making bleeding hard. All of those lines should use 200 series style teflon braided hose with heat shielding because everything needs to be routed past the manifold. Also a turbo beanie is a really good idea to minimise the chance of the car catching fire (under bonnet lining in particular) You also need to decide a cam cover breathing solution as well, will you vent externally via a catch can (probably illegal) or return to the intake (plumbing required and can oil up everything over time) Keep in mind the intake and exhaust piping in the engine bay will be custom so you either need to be able to fab ally and steel or have someone you can get a car that isn't running to. Get the wideband fitting welded into the dump pipe at the same time. Also, just my opinion, a screamer pipe attracts attention and doesn't add power, I'd plumb it back if you want to be allowed to keep the car on the road. BTW do you know anything about how healthy the motor is, and what power you are targeting? Doubling or tripling the factory power on an unknown motor is a little risky. Also fuel system will need some attention (pumps, high current hanger, direct power and earth feed, injectors etc)
