I am always going to keep my first car (my 33) i dont think i could ever part with her, even when i get another skyline lol :blink:
It was sad but wasn't hard to part with because I already had my dream car in the garage.
spotted the gutters at work being a bit higher than i remember haha...not good ....but not that bad.
Oh ouch I hope its not too bad!!
Spotted CeJay today. Car sounds awesome!!!
https://www.sau.com.au/forums/topic/30059-spotted/page/553/#findComment-4541228
Spotted Gus hitting said gutter at his work ... little bit of paint off nothing serious ... but at least the bar is made from plastic and flexes and not fiberglass otherwise it would have busted it good and proper
They are bloody high gutters I almost hit one myself on the opposite side ... about 30 seconds b4 you ..
Edited by hr32gts
https://www.sau.com.au/forums/topic/30059-spotted/page/553/#findComment-4541366
Thanks, although my car only looks slightly less dirty now lol.
Did spot a nice 32 gtr on the way home from work today at the kingsford smith / ginninderra drive interesction, gunmetal grey with nice rims, although he didn't look over at me as he was turning, looked like a new canberra car too, had YG---- number plates.
https://www.sau.com.au/forums/topic/30059-spotted/page/553/#findComment-4542801
Spotted Kat in her phat looking white GTR last night coming out of Hume onto the Monaro Hwy... I certainly hope you werent coming out of the Caltex/Woolies servo Kat!... Bad fuel there :)
I'll lay pounds to peanuts that she wasn't - I'm guessing she has been to the workshop to pick up her baby. And the way you are poking the yukky tongue out, I'm starting to think you've been drinking the fuel from there??
https://www.sau.com.au/forums/topic/30059-spotted/page/553/#findComment-4548688
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
