Spotted this outside my house... flamin mongrels http://www.canberracruises.com/forum/showthread.php?t=9455
rotten (explitifs removed)...... that shit sucks.. i've had a rock thrown through my R33's rear window for no good reason.. so i know how you feel.. they are expensive sods to if you can't find a second hand one.....
saw your post asking how hard it is to put the window in.. i've had to do a couple of window regs in R33's and windows in other cars.. it's just fidly.. it'd take about an hour or so to do..
https://www.sau.com.au/forums/topic/30059-spotted/page/563/#findComment-4682488
Spotted a maroon 32 with a big black wing followed by a gold 31 passing through the main stretch of Woden past the cinema this arvo.
Not sure why you needed so many revs to clear the speed bump, but i'm guessing you're just a fan of the noises it makes. Pity the bystanders weren't but hey.
https://www.sau.com.au/forums/topic/30059-spotted/page/563/#findComment-4682943
Spotted a white r33 yesterday near the AIS, gave a wave, and a received a wave. So hi to whoever the was.
Also spotted a silver r32 GTR at the intersection of belconnen way and coulter dr, he was turning turning at the lights, and i was turning at the other side. Gave a wave as we drove past each other, and received a wave.
https://www.sau.com.au/forums/topic/30059-spotted/page/563/#findComment-4683173
Oh if it was the GTR someone would be dead!
Window is all fixed now, $55 and an hour or two of Petey's time (he's a good one!).
https://www.sau.com.au/forums/topic/30059-spotted/page/563/#findComment-4683979
    • I don't think the shuffle can damage the turbos. It only happens at low shaft speeds and loads. It's just annoying (to some people - others are tickled by the effect) and it quite possibly reduces spool performance a little bit.
    • Oh dear. The panel beating needs to be done before the filler work. Do you have a photo of the dent before you started? Hard enough to not flex and only hit the high spots?  What do you mean it was just temporary?
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
