i think i saw the same Blue R33 GTR today. parkd on canberra ave. in fyshwick area i think it was
also saw a black 32gts as i was turning onto canberra ave from state circle. got a wave and tried to return1 lol, was fumbling with fone
https://www.sau.com.au/forums/topic/30059-spotted/page/565/#findComment-4694822
