HAHAHAHAHA well it would have been pissed when I'd done cleaning the inside and peeled it off then wouldn't I?!
rofl thanks Shell, only emphasising the subject of my recent PM. Well at least this makes things easier.
https://www.sau.com.au/forums/topic/30059-spotted/page/570/#findComment-4738082
Spotted white 33 turning left out of clift onto johnson this arvo, got a nod gave a wave ;)
also shell, just for you
(note: the top-left corner of the rubber seal for the windscreen is gone, so it might look crooked.
Can I has a cookie?
also, take note of the horrible condition of the paint on my roof: not my fault :(
Edited by Trozzle
https://www.sau.com.au/forums/topic/30059-spotted/page/570/#findComment-4738797
Welcome to SAU Scott! :P
mmm R34GTR noice :):(
hopefully we'll spot you around and add you to the thread... what colour is it? Any mods?
Its Sky blue only mods is exhaust and intercooler.
Wanting to put it on the Dyno to see what the car does, Are you guys going to do a Dyno day soon lol
https://www.sau.com.au/forums/topic/30059-spotted/page/570/#findComment-4742743
    • Absolutely could be. I collected data logs from when the O2 sensor was still out and also after I had replaced it so will try to compare them. Pretty confident that the affect is lowered with the new sensor, will check logs at the same RPMs/conditions.
    • Hey guys Long time lurker, I daily a nm35 stagea 250t rs four and I've had it for almost 2 years (very reliable 👌). Issues or just looking for information ill always find myself here having a read, so thought id join.  3inch stainless intake, pod filter, AM performance turbo dump pipe, 3inch hotdog, 3 and half inch stainless to 3 and half inch AM performance blast pipes. Bc racing coilovers. 18inch rims Hdi intercooler and trans cooler soon.  Here's my car
    • thanks for the advice on the box... i was thinking the 6 speed was better for cruising on the highway but on closer inspection and comparison the Rb 5 speed box was not too different...  So the choice is going to be the RB25 box... if I can save up and find one at the right price
    • Thanks Matt, yes that's what i am aiming for. Just going to apply the right voltage and grounds to the dash connector. Hence my search for these pins... any chance you know if these pins are in the same spot as the ones on the S15 Dash connector? as mentioned above on page 8?
    • Yes, unfortunately that's the one. Signal was noisy to begin with; after driving once and looking back at the logs I saw pressure constantly swinging between 0-200psi, or staying at 0 randomly for a few seconds. There's a lot of good sensors that share the same look and feel, so don't presume they're all bad. I bought mine for 20$ off Amazon and I should have read the reviews prior, as it's clear they're junk.  I purchased a lowdollerr motorsports sensor.
