black 34gtt followed me up camron ave then right onto eastern valley way, then left up college street then left onto hayden drive. the driver then gave it a bit when he passed me.. sounded nice. this would have been between 530 and 540 this afternoon
https://www.sau.com.au/forums/topic/30059-spotted/page/574/#findComment-4764230
Spotted bayside blue GTR in deakin and a white 34 GTT woden, lunch time today. Also spotted a white 33 with black bonnet at lanyon this evening around 9ish...
Oh and I almost forgot, spotted a silver r35 this morning near the canberra hospital (almost made me crash into the car infront of me, I WANT ONE!!!!!!!!!!!!!!!!!!!!)
Edited by dinero
https://www.sau.com.au/forums/topic/30059-spotted/page/574/#findComment-4764879
spotted a black R32 with black or dark rims on erindale dr going through the sulwood roundabout around 8pm, a white R33 turning from drakeford onto erindale drabout 9.30, then some f*ckwit in another white R33 with nsw plates almost took me out doing easily 130-140kmh on drakeford a minute or two later, then another white R33 on isabella a couple of minutes later.
https://www.sau.com.au/forums/topic/30059-spotted/page/574/#findComment-4768617
If anyone on here with a white 33 was driving through Calwell at about 6:30 tonight, you'd better check your tailights.
The one that cruised by my place had all hotplates off......
Had me worried then John. Would have been going past at that exact time myself only to realise that I was in the parents Hyundai instead :)
Actually spotted you going past work earlier this week, but again, I was in the Hyundai.
https://www.sau.com.au/forums/topic/30059-spotted/page/574/#findComment-4770386
FRIDAY:
white 33 GTR at the meet.. sorry mate, no idea who you were
SATURDAY:
black 33 on college street belco at around 230-245
white 33 on nettlefold then right onto lathlain street belco at around 230-245
white 33 that may have been a GTR on point hut road (in a car park near the bridge) around 345-415
SUNDAY:
silver 32 cutting mad sick at the motorkhana
millenium jade R34 GTR V-SpecII Nur at the motorkhana.. there is almost nothing better looking
Edited by Ex!$t3nZ
https://www.sau.com.au/forums/topic/30059-spotted/page/574/#findComment-4771583
    • I certainly fall into the annoyed camp, but glad to hear that if it's happening at low boost then I'm not likely going to blow a turbo and end up with metal shards in my oil. Just feels like it prevents me from really driving it without hesitation and "peak" performance. Wonder if it's the VCAM, it did an impressive job of shifting the torque curve and faster spool, but maybe now it's "too fast" and there's too much air for how open the throttle is.  Based on some other threads, will also do some reading on synchronizing the actuators. They are the default actuators that come on the Garrett's and I would think they would be set the same coming from the factory, but if the turbos don't actually work exactly the same way at the same time as previously mentioned, it would be worth making sure the actuators are actuating together properly
    • I went down this rabbit hole before, ended up sourcing a motor from the UK (I'm in Japan) which also didn't function correctly. With the original motor, I disassembled it and reassembled it and it works somewhat, sometimes. What I could deduce from all my screwing around is that there is calibration of the gears on the inside of the motor and two ramps on the main gear which activate switches that operate the motor and move the sunroof either to retract into the roof or tilt. Where I got stuck was that, it seemed in my case that one or both of the switches that are activated by the ramp on the gear did not always activate and thus the motor did not move, causing it to sometimes not retract or tilt (apologies, I've forgotten which way it didn't work.).  Of course this part is discontinued at Nissan now, it's the same part in the S15 but no other models. I also contacted the manufacturer of the component for schematics - forgot the name, they're based in Gifu - but they declined to share the information due to being bound by an NDA, sadly. Looking through my pictures now, it seems I last had a crack at this in 2022. See, I so kindly wrote "open" and "close" next to the switches. If you figure it out, please do tell me. Those little switches, with the red buttons may need to be replaced.
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
