black 34gtt followed me up camron ave then right onto eastern valley way, then left up college street then left onto hayden drive. the driver then gave it a bit when he passed me.. sounded nice. this would have been between 530 and 540 this afternoon
https://www.sau.com.au/forums/topic/30059-spotted/page/574/#findComment-4764230
Spotted bayside blue GTR in deakin and a white 34 GTT woden, lunch time today. Also spotted a white 33 with black bonnet at lanyon this evening around 9ish...
Oh and I almost forgot, spotted a silver r35 this morning near the canberra hospital (almost made me crash into the car infront of me, I WANT ONE!!!!!!!!!!!!!!!!!!!!)
Edited by dinero
https://www.sau.com.au/forums/topic/30059-spotted/page/574/#findComment-4764879
spotted a black R32 with black or dark rims on erindale dr going through the sulwood roundabout around 8pm, a white R33 turning from drakeford onto erindale drabout 9.30, then some f*ckwit in another white R33 with nsw plates almost took me out doing easily 130-140kmh on drakeford a minute or two later, then another white R33 on isabella a couple of minutes later.
https://www.sau.com.au/forums/topic/30059-spotted/page/574/#findComment-4768617
If anyone on here with a white 33 was driving through Calwell at about 6:30 tonight, you'd better check your tailights.
The one that cruised by my place had all hotplates off......
Had me worried then John. Would have been going past at that exact time myself only to realise that I was in the parents Hyundai instead :)
Actually spotted you going past work earlier this week, but again, I was in the Hyundai.
https://www.sau.com.au/forums/topic/30059-spotted/page/574/#findComment-4770386
FRIDAY:
white 33 GTR at the meet.. sorry mate, no idea who you were
SATURDAY:
black 33 on college street belco at around 230-245
white 33 on nettlefold then right onto lathlain street belco at around 230-245
white 33 that may have been a GTR on point hut road (in a car park near the bridge) around 345-415
SUNDAY:
silver 32 cutting mad sick at the motorkhana
millenium jade R34 GTR V-SpecII Nur at the motorkhana.. there is almost nothing better looking
Edited by Ex!$t3nZ
https://www.sau.com.au/forums/topic/30059-spotted/page/574/#findComment-4771583
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
