Spotted an R32 GTR past theodore onto the monaro this morning. very nice!
Spotted two maroon r33's yesterday on the monaro, one s2 turning off the Queanbo and a s1 behind me most of the monaro (I was in my sis's pulsar - which i forgot to take the P plates off by the way....)
https://www.sau.com.au/forums/topic/30059-spotted/page/577/#findComment-4787133
JD travelling in style to work this morning. I was in such a daze this morning, saw the waving and my mind said yep, JD, wave back... My hand took an extra minute to react...
You went through the lights at Theodore while I was waiting to turn, and it only took me about 5 K's to catch up :D
The old diesel ute has been called many things (especially the time it broke down halfway up the Clyde), but stylish isn't one of them.....
https://www.sau.com.au/forums/topic/30059-spotted/page/577/#findComment-4787393
You went through the lights at Theodore while I was waiting to turn, and it only took me about 5 K's to catch up :)
Since I drive like a grandma to work, I thought you would have caught me a lot sooner than that! It's always an entertaining scenario in the morning when I have people go flying past me at warp 10 in their Kia's only to stop at the roundabout and then the lights where we turn off..
Haha, poor ute. C'mon, how is it not soooo much more stylish than a GTR, sheesh...
https://www.sau.com.au/forums/topic/30059-spotted/page/577/#findComment-4787473
I was stealth in the Audi. Had dropped my car off at Inline and in a daze my husband turned instead of going straight when we were leaving Qbn so slight detour lol.
Nice pile of tyres at Inline too Reece. Pity they're not the same size as mine I mighta slipped Chris a $50 to accidentally mix them up ;)
https://www.sau.com.au/forums/topic/30059-spotted/page/577/#findComment-4791290
Spotted Yellow 34 right out the front of erindale leisure centre as I drove past blinding them no doubt.
Also, some piece of shit (pardon the language) thinking he's f**king funny spitting on my car as he drives beside me in traffic coming down erindale drive - HAHA f**kWIT DIDN'T EXPECT ME TO SEE YOU DO IT HUH? BET YOU DIDN'T EXPECT ME TO GET YOUR PLATES AND MAKE/MODEL EITHER?
Good work to the above dipshit, you'll get your own.
https://www.sau.com.au/forums/topic/30059-spotted/page/577/#findComment-4792380
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
