Ptttf sif a 33 isn't sexy!!
The 33 does have sex appeal (to girls and male foxymorons *coughtrozzlecough*)
Ill prove it in a few weeks with some photos :huh: (Trozzle, ZCR and Turismo know what I am talking about)
Between thurs night/Friday night spotted a white 33, black 33 (chick), maroon 33 (chick), silver 32, Trozzle, Shell, ZCR, GTRKAT (Maybe not sure, parked in Civic fri night), Turismo (Yaris), Sl33py and a few others :D Was a good two days for spotting people!
Edited by Melly
https://www.sau.com.au/forums/topic/30059-spotted/page/585/#findComment-4847898
Ill prove it in a few weeks with some photos :D (Trozzle, ZCR and Turismo know what I am talking about)
Between thurs night/Friday night spotted a white 33, black 33 (chick), maroon 33 (chick), silver 32, Trozzle, Shell, ZCR, GTRKAT (Maybe not sure, parked in Civic fri night), Turismo (Yaris), Sl33py and a few others :banana: Was a good two days for spotting people!
cant help noticing you left me out :)
https://www.sau.com.au/forums/topic/30059-spotted/page/585/#findComment-4848845
Lets see spotted a silver M35 stagea in a certain car park in civic this arvo, a white 33 in another carpark, mccready giving someone a driving lesson in the mini, and a v35 followed me in civic, all in the space of 1/2 an hour this afternoon lol.
https://www.sau.com.au/forums/topic/30059-spotted/page/585/#findComment-4852688
Spotted nerm and what looked like it could be ZCR, if not it was a silver 32. at 10:00 tonight over in erandale, near the fitness centre thing. nerm was following the silver 32.
yeah that was us, i was following a mate in a lifted patrol and turismo was in a renault clio up front. where were you?
https://www.sau.com.au/forums/topic/30059-spotted/page/585/#findComment-4857647
    • Ok I get you. But isn’t the butterfly intake a headache with the +T?  see this is my plan so far but please advise me into the right direction.  Nistune Ecu, 1000cc Bosch injectors, TD05 or TD06 Kinugawa turbo using stock rb25det exhuast manifold, walbro fuel pump unsure of model I think it’s 450/460, spitfire coils and sparks to suit and a R35 MAF sensor and boost sensor.    I was thinking maybe do a cheap eBay plenum $400-500 or try find a stock det neo intake. I think I’d port match it so it’s getting the full capacity but open to advice please.  Thanks
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
