Then I'll be a little more fitting when having to set a good example for Shell and Melly, yay!
wait....shit-
I am confused.... Aww troy maybe you should enter Miss World with me.... No wait.. People might think you are prettier than I am...!
https://www.sau.com.au/forums/topic/30059-spotted/page/587/#findComment-4866820
Give a wave if you spotta "Dusty pink" TS Magna with rOSSI 18" chrome's ~ tis me :) . Hopefully Sinista will be back by November/Chrissy. Not long.......I'm getting very Xcited :D (kleeneX pleeze)!
Then there will be some fun...
Edited by Sinista32
https://www.sau.com.au/forums/topic/30059-spotted/page/587/#findComment-4869257
am I allowed to ask how long its been off the road?? oops. I had enough trouble with 3 months.
Spotted a white stagea this arvo in civic.
Off the road in Jan 2005 for an Engine rebuild. Back on the road for 9 days mid June 2006 :'(
https://www.sau.com.au/forums/topic/30059-spotted/page/587/#findComment-4870189
spotted a blue R34 GTR with a mashed front end in a yard in fyshwick! poor thing... I want it.
There's a blue 33 in the Qbyn wreckers too. Front slightly mashed but all else is good if anyones looking for parts...
https://www.sau.com.au/forums/topic/30059-spotted/page/587/#findComment-4870192
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
