Can't say I've noticed that! With my new tyres and some fixed suspension my baby is holding to the ground like glue!
Spotted a gunmetal (or was it silver??? too early in the morning!) 33 turning from Ginninderra drive onto the GDE this morning on my way to work. As per usual when I make spottings, I was in the Audi :down:
https://www.sau.com.au/forums/topic/30059-spotted/page/590/#findComment-4883246
Hmm well the tyres are nearly two years old with about 20,000km on them, i think.. Although, Kat, are you running the RS-R's, mine are only the SS's..
Nope I be running Bridgestone RE55's.
Funny though, you get used to how your car is feeling, I knew it needed work but I didn't quite realise how bad it was until I remembered how good it could feel when I got it back. I think that makes sense... Oh well it's Friday and my brain has officially shut down!
https://www.sau.com.au/forums/topic/30059-spotted/page/590/#findComment-4883943
Also W1ngnut and someone in a gunmetal 32 with an SAU sticker that I haven't seen/met before both on Monary hwy this morning.
That was me :P - BTW it's Silver not Gun Metal (its a bit dirty at the moment though).
Haha spotted Trozzle and Bullet32 on Monaro this morning. Does anyone else think the roads might have a lot of dust/dirt on them? I felt like i had very low grip on the way to work and I don't think the 595's are due to be replaced already..
It was very slippery on the hwy this morning, its the left over crap from dirty rain on the surface of the road after the water dries up.
P.S. I love the wheels on your car! :devil:
https://www.sau.com.au/forums/topic/30059-spotted/page/590/#findComment-4883999
RHGY? Did you cap it before FW? wait, wtf....
Dead guy? wowowwwz explain
by Rh. I meant rush hour. wasnt sure if i wasnt meant to mention it. haha
and yer after everyone from rush hour went to the strip club, my friend and i (we both arnt 18) were driving back home and we saw heaps of cops taking pics of some dead guy.
has it been on the news yet?
https://www.sau.com.au/forums/topic/30059-spotted/page/590/#findComment-4884648
Your running RE55's for the street? :D
https://www.sau.com.au/forums/topic/30059-spotted/page/590/#findComment-4886294
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
