Spotted a very tidy white 32 GTR (Autostyle sticker) and not far from that a not so tidy white 32 GTS-t with black bonnet and front bar near Dan Murphy's tuggeranong. Credit to the GTR owner inside and out. I cant understand skyline owners who let their rides deteriorate like the GTS-t. Especially a 32 FFS...
https://www.sau.com.au/forums/topic/30059-spotted/page/606/#findComment-5071161
No one is allowed to judge me on the outside of my car until it is painted. LOL
https://www.sau.com.au/forums/topic/30059-spotted/page/606/#findComment-5071186
Sorry Matt :D a lil judgmental when I see a 32.
If it was a 33 or maybe 34 I wouldn't bother commenting. Nothing beats the hard lines, performance and the real driving experience of the 32 IMHO....
(quickly paddles backwards)
Edited by Sinista32
https://www.sau.com.au/forums/topic/30059-spotted/page/606/#findComment-5071260
31 beats all.
https://www.sau.com.au/forums/topic/30059-spotted/page/606/#findComment-5071298
Spotted a silver R33 at about 6:30pm on Canberra Ave heading into QBN, just seemed to be parked on the side of the road and I couldn't see anyone in it hope it hasn't been stolen.
That was mine. Water got into my map sensor somehow. My mate put a new map sensor in my ECU and it's running fine again thank god. Spotted a silver R33 going past while I was working on it, looked like he was having a laugh at me but not sure. Know I saw a couple of commodore drivers getting a kick out of it.
https://www.sau.com.au/forums/topic/30059-spotted/page/606/#findComment-5080684
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
