Spotted something....thought it was an old skool celica at first, but the word "skyline" made me think otherwise...either way I don't know the old models of skylines (I mean what could POSSIBLY have come before the R32? A Dinosaur????)...this was on Hindmarsh drive about 4:30 yesterday in weston.
All I have to say is holy shit, that is NOT the original engine....I shit myself on the spot. Very impressed mate :( also gave wave and got one, woop woop
https://www.sau.com.au/forums/topic/30059-spotted/page/612/#findComment-5135089
Spotted burgundy R33 turning right onto ginnindera drive off kingsfordsmith at 8:10 this morning, and then further up the road at kuringa and kingsford smith spotted a silver (i think) R35, after seeing it go past me i was to busy avoiding crashing after trying to turn my head all the way around.
oh and hi peoples
https://www.sau.com.au/forums/topic/30059-spotted/page/612/#findComment-5135113
sounds like the original GTR from the 70's, the KPGC110 GT-R (Built from 72-77) it had a 2ltr engine
Edited by nerm
https://www.sau.com.au/forums/topic/30059-spotted/page/612/#findComment-5135350
oh and hi peoples
Hey Swannie - there not bad. I like this one.
https://www.sau.com.au/forums/topic/30059-spotted/page/612/#findComment-5136715
Spotted dark green/gunmetal/dark blue or something colour R33 (s1 I think) and a white R33 s2 both on Ashley drive this afternoon, both headed towards richardson....I was on the side of the road on my pushy, gave a wave to both and got some form of response both times lol
https://www.sau.com.au/forums/topic/30059-spotted/page/612/#findComment-5138202
Spotted a grey 33 turning right onto william hovel dr off drake brockman, got a wave.
Also spotted Kats GTR at autotech with a very nice looking preleminary Kw reading on the dyno :blush:
Also Spotted my 34GTT making 214.6rwkw, still with stock turbo, injectors, afm and fuel pump. :D:bunny:
https://www.sau.com.au/forums/topic/30059-spotted/page/612/#findComment-5139625
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
