spotted
1. about 8:30am today driving toward the airport pasing duntroon roundabout, Burgundy R33 GTS-T front mount, aftermarket front bar, fat chrome wheels, very tidy looking.
2. Very slick and sexy black Autech staega 260 parked near the Reid tafe. credit to the owner, it looked awesome :thumbsup:
https://www.sau.com.au/forums/topic/30059-spotted/page/616/#findComment-5168301
YES SPOTTED FARK ABOUT TIME BEEN TOO LONG!!! lol
Were you going through the roundabout, or were you behind me on Johnson? I was merely thinking about gambling - whether I hit boost or not! hmm...haha I fking hate having to drop back to 1st at that intersection, always best if I can coast through in 2nd!
https://www.sau.com.au/forums/topic/30059-spotted/page/616/#findComment-5168315
I was coming from Tharwa Drive (Theodore). I can understand not kicking back to 1st in the 33, just everyone else that cuts me off going through that roundabout gives me the shits cause (esp in the wet), thats a slippery corner and the subie's grip levels aren't the best even at low speed. I just don't want to hit anyone.
I was actually watching you closely with the window down to hear if there was any 'sustained loss of traction' happening :):thumbsup:
https://www.sau.com.au/forums/topic/30059-spotted/page/616/#findComment-5168325
hahaha, yeah...it's a shit intersection :thumbsup: but nah, that's not my kinda corner, ESPECIALLY with traffic around, to skid in the wet....I much prefer turning left off Hindmarsh onto Canberra Ave in 2nd....then into 3rd....then gain traction and coast down to work in 4th...though again, not with traffic :) lol
https://www.sau.com.au/forums/topic/30059-spotted/page/616/#findComment-5168392
Had a dream day of skyline spotting today and thought I'd just have to share. First I saw a gun-metal R33 GTST turn onto Canberra avenue off the Monaro Highway Fyshwick, followed moments later by a black R32 GTR on Barrier St. Then as I was walking to my car on Lyell Street after work, a midnight purple (possibly black,it was overcast :P) R34 GTR drove past, very impressive.
https://www.sau.com.au/forums/topic/30059-spotted/page/616/#findComment-5169160
