Cruising the streets of the Berra today in the ecologically awesome work hybrid camry I've seen:
Shell - Northbound on Sulwood in her Banannacar
A white R33 with red plates - up on ramps in its garage in gordon
A silver 33 with a scuff in its bumper in Banks (which according to its sticker is 'For Sale')
And because I bat for the other team (Toyota)
3 MR2's - Just cause they're awesome!
Ha
https://www.sau.com.au/forums/topic/30059-spotted/page/625/#findComment-5267416
Spotted RB ONEVIA.... finally!!!!!!!! :) Back at the big lights I was thinking, must look around and pay attention! LOL! Then go around the corner and there you were :bunny:
Broken_R31, yep that would have been me (assume you mean Athllon Dr). So you were in a Camry?.... hmmm surprisingly, I didn't spot you back :)
https://www.sau.com.au/forums/topic/30059-spotted/page/625/#findComment-5267455
lastnight on the way back from lyneham, stoped at the lights in front of the ainslie fire station (wakefield and limestone avs), a fire truck left. then down at the begining of the monaro near duntroon, another fire truck went through the lights there, then closer to the hindmarsh bridge, another fire truck and about 10 secs after was the police crash investigation van all heading out airport/ majura rd way. i put my money on a head-on on majura but listened to the news this morning and nothing..... anyone know anything?
https://www.sau.com.au/forums/topic/30059-spotted/page/625/#findComment-5270819
The women of Canberra had learnt of my whereabouts.....was surprised you didn't see the riot cops too! :D
https://www.sau.com.au/forums/topic/30059-spotted/page/625/#findComment-5272111
Spotted black 32 GTR turning from ginninderra dr onto coulter after work, had GTRCHIK plates, possibly sa or wa?
Blonde girl driving it.
have seen this parked in belconnen, at a house along with a supra, won't say exactly where though, regularly parked at that spot. nice gtr
https://www.sau.com.au/forums/topic/30059-spotted/page/625/#findComment-5276140
Spotted x 3
Yesterday about 5:30pm
Silver M35 Stagea stock bar exhaust in Manuka, travelled with it from the lights near the post office/ servo until it turned off at the lights in fyshwick to head south on the monaro. I was in the white territory
this morning about 8:30
burgundy R33 GTS-T with front mount as it drove over the airport overpass road headign towards Queanbeyan, i flashed and waved, but don't know if you saw :wacko: (I drove my GTR today!)
8:45
Black R33 GTS-T parked near the Civic CIT
https://www.sau.com.au/forums/topic/30059-spotted/page/625/#findComment-5282545
    • Not sure the US can import anything other than the C34 Stagea's, but if you can and you need to to tow, DO NOT under any circumstances get an M35 Stagea. If it is just as a family car and your country/state allows it, absolutely and definitely get an M35 (3.5L if possible as it is effectively a 350Z) over a C34.
    • Punch your VIN (nm35-xxxxxx) into Amayama.com You can see everything there quite easily.
    • Thanks for that, I'll check it all out. I can always do the brakes last anyway if its a problem.  The 16's are super cool, if they do fit I'll cruise around with them for a bit.
    • Well, that's kinda the point. The calipers might interfere with the inside of the barrels 16" rims are only about 14" inside the barrels, which is ~350mm, and 334mm rotors only leave about 8mm outboard for the caliper before you get to 350, And.... that;s not gunna be enough. If the rims have a larger ID than that, you might sneak it in. I'd be putting a measuring stick inside the wheel and eyeballing the extra required for the caliper outboard of the rotor before committing to bolting it all on.
    • OK, so again it has been a bit of a break but it was around researching what had been done since I didn't have access to Neil's records and not everything is obvious without pulling stuff apart. Happily the guy who assembled the engine had kept reasonable records, so we now know the final spec is: Bottom end: Standard block and crank Ross 86.5mm forgies, 9:1 compression Spool forged rods Standard main bolts Oil pump Spool billet gears in standard housing Aeroflow extended and baffled sump Head Freshly rebuilt standard head with new 80lb valve springs Mild porting/port match Head oil feed restrictor VCT disabled Tighe 805C reground cams (255 duration, 8.93 lift)  Adjustable cam gears on inlet/exhaust Standard head bolts, gasket not confirmed but assumed MLS External 555cc Nismo injectors Z32 AFM Bosch 023 Intank fuel pump Garret 2871 (factory housings and manifold) Hypertune FFP plenum with standard throttle   Time to book in a trip to Unigroup
