Cruising the streets of the Berra today in the ecologically awesome work hybrid camry I've seen:
Shell - Northbound on Sulwood in her Banannacar
A white R33 with red plates - up on ramps in its garage in gordon
A silver 33 with a scuff in its bumper in Banks (which according to its sticker is 'For Sale')
And because I bat for the other team (Toyota)
3 MR2's - Just cause they're awesome!
Ha
https://www.sau.com.au/forums/topic/30059-spotted/page/625/#findComment-5267416
Spotted RB ONEVIA.... finally!!!!!!!! :) Back at the big lights I was thinking, must look around and pay attention! LOL! Then go around the corner and there you were :bunny:
Broken_R31, yep that would have been me (assume you mean Athllon Dr). So you were in a Camry?.... hmmm surprisingly, I didn't spot you back :)
https://www.sau.com.au/forums/topic/30059-spotted/page/625/#findComment-5267455
lastnight on the way back from lyneham, stoped at the lights in front of the ainslie fire station (wakefield and limestone avs), a fire truck left. then down at the begining of the monaro near duntroon, another fire truck went through the lights there, then closer to the hindmarsh bridge, another fire truck and about 10 secs after was the police crash investigation van all heading out airport/ majura rd way. i put my money on a head-on on majura but listened to the news this morning and nothing..... anyone know anything?
https://www.sau.com.au/forums/topic/30059-spotted/page/625/#findComment-5270819
The women of Canberra had learnt of my whereabouts.....was surprised you didn't see the riot cops too! :D
https://www.sau.com.au/forums/topic/30059-spotted/page/625/#findComment-5272111
Spotted black 32 GTR turning from ginninderra dr onto coulter after work, had GTRCHIK plates, possibly sa or wa?
Blonde girl driving it.
have seen this parked in belconnen, at a house along with a supra, won't say exactly where though, regularly parked at that spot. nice gtr
https://www.sau.com.au/forums/topic/30059-spotted/page/625/#findComment-5276140
Spotted x 3
Yesterday about 5:30pm
Silver M35 Stagea stock bar exhaust in Manuka, travelled with it from the lights near the post office/ servo until it turned off at the lights in fyshwick to head south on the monaro. I was in the white territory
this morning about 8:30
burgundy R33 GTS-T with front mount as it drove over the airport overpass road headign towards Queanbeyan, i flashed and waved, but don't know if you saw :wacko: (I drove my GTR today!)
8:45
Black R33 GTS-T parked near the Civic CIT
https://www.sau.com.au/forums/topic/30059-spotted/page/625/#findComment-5282545
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
    • When I said "wiring diagram", I meant the car's wiring diagram. You need to understand how and when 12V appears on certain wires/terminals, when 0V is allowed to appear on certain wires/terminals (which is the difference between supply side switching, and earth side switching), for the way that the car is supposed to work without the immobiliser. Then you start looking for those voltages in the appropriate places at the appropriate times (ie, relay terminals, ECU terminals, fuel pump terminals, at different ignition switch positions, and at times such as "immediately after switching to ON" and "say, 5-10s after switching to ON". You will find that you are not getting what you need when and where you need it, and because you understand what you need and when, from working through the wiring diagram, you can then likely work out why you're not getting it. And that will lead you to the mess that has been made of the associated wires around the immobiliser. But seriously, there is no way that we will be able to find or lead you to the fault from here. You will have to do it at the car, because it will be something f**ked up, and there are a near infinite number of ways for it to be f**ked up. The wiring diagram will give you wire colours and pin numbers and so you can do continuity testing and voltage/time probing and start to work out what is right and what is wrong. I can only close my eyes and imagine a rat's nest of wiring under the dash. You can actually see and touch it.
