I spotted a reddish coloured R34 (I think) with those lights that were mentioned earlier... Hmmm my verdict is not cool! I was too horrified seeing the lights to notice the rest of the car properly!
Also spotted a 4 door gunmetal 32 with a P plate at Erindale earlier tonight near Goodberries.
https://www.sau.com.au/forums/topic/30059-spotted/page/629/#findComment-5336392
hahahaha, I really need to recognise your car!
I love just putting down the hill, reaching 80 just as you go through the 80 signs, having people get annoyed and shoot past me....then either rolling straight past them as you time the roundabout traffic nicely, or just booting it out of the roundabout flustering them a little.
Some people need to learn2traffic
https://www.sau.com.au/forums/topic/30059-spotted/page/629/#findComment-5336684
Hahaha I thought I was the only one that ever did that with the 80 signs there...
The only problem is with the Subie, I need to keep as much momentum as I can as it is very lethargic. Thus why everyone shoots past me up the hill but I generally pass them down the hill..
https://www.sau.com.au/forums/topic/30059-spotted/page/629/#findComment-5336761
I saw this a while ago when I was dropping someone off at a formal and it was towing a boat with Supra tags all over it. Not sure what that's about though.
Hrmm maybe it means something different then.... little does he know car nuts all over Canberra are lol'ing at him ;)
https://www.sau.com.au/forums/topic/30059-spotted/page/629/#findComment-5337294
Bring it girly.
Oh, I'd tread lightly if I were you boy :-)
Spotted a Silver R35 GTR in Fyshwick sitting in front if Onya Bike friday afternoon.
Spotted an old ford falcon (EB or something) today with a Magna badge on top of the falcon badge on the boot...... :banana:
https://www.sau.com.au/forums/topic/30059-spotted/page/629/#findComment-5340710
So, who is it with the white series 2 R33 that's installed the Audi style LED running lights on top of their driving lights?
yeah that would be me....
liked the look and decided to try something different with her... :D
the only thing now i think i'll have to do is get some narva xenon blue lights as the standard suckers clash with the bright white from the LED's..
https://www.sau.com.au/forums/topic/30059-spotted/page/629/#findComment-5343850
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
