yeah, spotted heaps of Skyrines on the way home yesterday.
James, your 31 looks fair decent, suspension looks way firm...... Good for Dorifto!!!!11
but what the hell happened to the old boosted Red Silo?
https://www.sau.com.au/forums/topic/30059-spotted/page/680/#findComment-5939463
Gray r34 (Sinista?) & r33 with domo kun hanging off the back from city to tuggerz. we were all driving like grandmas fuel expensive these days . i was in black r34 with p plates.
Yes Sinista (Jnr) in the pilots seat of the 34 as the black supra is being readied for a bigger heart (1jz to 2jz). Mini cruise looks good .
Some times when you go slower it gives the impression your car is a beast waiting to unleash :thumbsup:
I've seen cars race up beside and then back it off.
https://www.sau.com.au/forums/topic/30059-spotted/page/680/#findComment-5941591
Spotted and waved to Jimmy this morning... Heading up the hill towards Calwell.
I didnt get a wave back :( (I was driving my 4WD though).
Hahahaha 4WD's are not relevant to my interests, sorry mang... :D
besides, i'm usually still heavily asleep while i'm driving to work....
https://www.sau.com.au/forums/topic/30059-spotted/page/680/#findComment-5949076
    • They are, a good friend of mine bought one to replace his blow factory turbo, running a Toshi Tune reflash. Just use their supplied water/oil lines and you're good to go. At the time, they were like $900 delivered.
    • This is an option for 100% bolt on, the GCG high flow -  https://gcg.com.au/turbo-charger-upgrade-skyline-gtst-2iu-xtrgts-s1.html Also, I'm pretty sure hypergear does a high flow that is 100% bolt on, it just doesn't make as much power as their bigger high flows.  Even if you get a hypergear turbo that requires you to chance the intake piping, it is a really simple modification. It can be as simple as a piece of silicon hose and you pop a filter on the end. It doesn't have to be some crazy pie cut titanium work of art intake pipe.  If you have the ability to swap the turbo yourself, you would be able to sort the intake piping out.
    • Just as a thought, if it's in neutral, thats your drive line disconnect, not the clutch. Clutch slip at the dyno with pedal fully out, is actually adding a second disconnect. So it's not a clutch issue if you're in neutral. Just a bit of friction dragging the output around while in the air.
    • The HG high flow is excellent, and costs about the $$ you're talking about. But it, and probably every other highflow, uses a diffeent core than the original turo, and the original Hitatchi core is quite long. So, I think it is inevitable that there is likely no such thing as a highflow that just "bolts on" with no other effort required. And the same is likely true for HG's outright replacement "bolt on" turbos (the ATR things). And the same is likely true for anything similar from elsewhere. I have no idea if the cheap Chinese/Taiwanese complete turbos from eBay/Temu/etc are as bolt on as they claim. I mean, they claim the bolt onto the NAs as well as the turbos, and we know that can't be "bolt on". But it wouldn't matter because I'm not buying a $169 4 psi turbo for anything other than a paddock basher.
    • Bummer...yeah i "need" something to "ease" up the work and for my driving it would be enough.    Iam counting the tune "without" turbo. I do not mean "cheap" like something from Temu around 200 USD, "Cheap" is something around 1000 USD?
