Spotted a chick in a silver V35 bout 5ish his afternoon. Learn to merge and pay attention!! Hot tip, I don't like being cut off by someone who is on the phone and not looking at the road!
She proceeded to talk on the phone the whole length of Majura Road and Horsepark drive and to add to it, when she was at the lights I saw she had phone in one hand and ciggie in the other!! Nice work! :down:
https://www.sau.com.au/forums/topic/30059-spotted/page/682/#findComment-5957761
I actually saw an unmarked falcon going the opposite way I was hoping they would see!
Stupid bitch was actually driving under the speed limit and holding cars up as well as saw her veering off the actual road a few times. Want to slap people like like that!
Haha sorry if she's on here but that's really f**king dumb stuff.
https://www.sau.com.au/forums/topic/30059-spotted/page/682/#findComment-5957847
Spotted the white R34 GTT with the big square wing at Fyshwick markets on Sunday. Was going to wave but I was in the Audi and I thought you'd have nfi who I was!
Also spotted that white R34 this morning with the number plates THE34T or similar parked near my work out Belco way :)
https://www.sau.com.au/forums/topic/30059-spotted/page/682/#findComment-5968824
Hi Kat,
Yep I was out that way this morning doing a little work ..:closedeyes:
While I was there I did spot a white 33, by the time I saw it didn't have time to wave ... sorry mate if you're on here, I did think about it!
Edited by THE34T
https://www.sau.com.au/forums/topic/30059-spotted/page/682/#findComment-5969640
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
    • Wouldn’t touch par if they gave it to me. You need to ask how much power you’re looking to make and then add about 50% to it because that’s what you’ll end up making  The factory box says no more at about 350kw or so, the upgraded synchro boxes won’t handle much over 500kw for long and at that point you’re looking at an auto or dog engagement manual,  once you’ve gone dog engagement you may as well go sequential, they cost a little bit more but it’s worth it  also while you’re at it you should upgrade the transfer case with 10 friction plates
