Spotted 2 R33 GTS-T's tonight.
One on Canberra Ave going into QBN, I noticed both guys checking out my R32. Hope you boys got a good look.
And the other was parked in the relief rd carpark for Crawford Rd. That one was a 4 door :)
Black?? Nice chrome 19's? If so that would have been me. Few min later some little punks at QBN skate park decided to throw shit from the bush's
Couldnt find them after snapping 2nd and pointing the lights straight into the bush
https://www.sau.com.au/forums/topic/30059-spotted/page/689/#findComment-6025704
Hey That was me in the white R33 :action-smiley-069: turning into Kambah, seen u around a few times now :thumbsup:
I've seen you around once or twice, just didn't figure you were a member.
And wowa, Nik posting 3 times in as many days, has the rapture happened? :P
https://www.sau.com.au/forums/topic/30059-spotted/page/689/#findComment-6025841
If you have cool trick rear lights and you and you passenger were checking my r32 out then yeah lol.
Little shits, no respect. Would like that to happen to them when they start driving.
https://www.sau.com.au/forums/topic/30059-spotted/page/689/#findComment-6026053
Yeah no worries man.. I havent got many distinguishable features... 16mm holes in my ears, 3 stars tattooed around my neck and half a sleeve. Average joe i suppose.
Spotted ya in the gym this arvo, was asking my mate if he knew anyone by your description and then bam - you were right behind us lol. You looked a bit busy and I couldn't remember your name so I didn't bother you ;)
https://www.sau.com.au/forums/topic/30059-spotted/page/689/#findComment-6026061
Just spotted something black and shiny at the lights turning onto state circle. 9:30pm
Couldnt make out what it was because of the poor lighting.
Looked very nice and shiny tho
I gave him a wave with my factory BOV
Edited by Kasko
https://www.sau.com.au/forums/topic/30059-spotted/page/689/#findComment-6027851
hahaah really? i was talking to my friend about how there was a sau member who goes to the gym.
and its Karl.. im pretty approachable too, always up for a chat and some lulz.
https://www.sau.com.au/forums/topic/30059-spotted/page/689/#findComment-6027918
Ive been spotting a lot of 34's getting around lately. black and silver and yellow ones.
Hahah Gus you should have seen our little social cruise the other day, more 34's showed up than 33's and there wasn't a 32 in sight! Oh how times have changed.
https://www.sau.com.au/forums/topic/30059-spotted/page/689/#findComment-6031059
Yay Gym :wub: Which Gym?? :yes:
Nvermind, read back, Anytime Tuggerz... I might see you guys there, I go to different anytime gyms depending on my mood lol :)
Spotted a green 32 in Fyshwick (see it almost daily), also a pretty blue 33 in Fyshwick and a black 34 in Fyshwick :)
https://www.sau.com.au/forums/topic/30059-spotted/page/689/#findComment-6032376
    • The fab work can be as simple as a couple of silicon hoses and clamps to the factory piping.
    • Just sounds like either way you need to do some fab work to get everything to fit, so why limit yourself at that point? If the GCG high flow option is zero effort in and out swap though I'd probably do that. It's almost certainly lowest risk, lowest cost, etc. The HKS GTIII-RS option that Kapr mentioned is laughably expensive for what it is, they charge the exact same for two turbos on the RB26 so their margins are off the charts on that thing.
    • Intake manifold is not a part of the issue. The turbo bolts to the exhaust manifold. That is easy. But close your eyes and picture the physical situation. That is a T3 flange on the manifold and a T3 flange on the turbo. As long as any new turbo has a T3 flange on the exhaust housing, that exhaust housing will bolt to the exhaust manifold. This places the exhaust housing in the same place as the stock one. But now move your mental attention a little further forward. The location of the compressor housing is set by the length of the turbo's core. The stock turbo had a long core. Let's say that it is..... 100mm long. So that would place the compressor housing 100mm forward of the exhaust housing. But a highflow, might well have a centre core that is shorter. Let's say that it is only 70mm long. Now the compressor housing will be 30mm further back in the engine bay than the stock one. This DOES move the turbo's compressor outlet backwards. It also moves the compressor's inlet backwards. You will very likely have to do some work to both the inlet and outlet piping to make everything connect again. I am not say this to make it out to be a bigger deal than it is. I am just pointing out that "bolt on" is sometimes not quite bolt on. The highflow from GCG that Murray linked above (https://gcg.com.au/turbo-charger-upgrade-skyline-gtst-2iu-xtrgts-s1.html ) uses a core that is the same length as the stock core, and so does not require this extra work. It will look very much like the stock turbo. No-one uses GTR turbos of any flavour (stock, or aftermarket) in a single turbo application on RB20/25. It's not a thing. Yes, people have been putting on GT3076, GTX3076 (and bigger and smaller versions of those) and G30s (of various sizes) onto RB20/25 since forever. But these are not "bolt on". Everything except the 4 bolts to the exhaust manifold change with these. And genuine Garretts are expensive. Non-gen, like Pulsar, etc, are cheaper, variously as good or nearly as good. But still not bolt on. No-one in the right mind would pay for an HKS turbo. Not in this modern day and age. Well, yes, the GCG highflow. You could ask HG what he can do to make the compressor housing sit in the original location. There are surely others doing highflows around the world. And some of the eBay/Temu ones (as reported by Dose) work and don't die. Bit of a lottery though. I would send your turbo to GCG (here in Oz) to be highflowed if you want a trivial no-extra-work option. But seriously, the work required to change inlet and outlet piping is not that hard. That's a boost control problem, not a turbo problem.
    • Thank you all for the replys 🙂 I know that intake would be different but that is one pipe at it is not that hard to get(custom one). I meant mainly bolt to the stock manifold and the turbo elbow. I looked and many sites/forums but they are just "old" with some old HKS turbos from GT-R i guess? What about some Garrets?  Or any other turbo? Is there even a turbo which i can just bolt on? 😄 And yeah i know about that new HKS but that is like 2000k USD without taxes/shipping in here   Iam getting a touch up tune but my "problem" is that on the "not" hot day iam getting peaks around 0,9 bar...and when it was around 15 Celsious i saw peak around 1 bar which is just too much for stock turbo. And of course turbo is old and i like to get some new one for a piece of mind 🙂
    • I'm working on the assumption that our friend Jasmine here is a Russian (or, possibly Ukrainian) spammer/spambot, based purely on the number of such that I have been having to neuter in the last few weeks. IP address for the OP above was in WA. But that could have been via VPN. Posting at quarter to 4 in the morning is a good sign of being from somewhere in Europe. The last Jasmine that I kicked in the cooch was IP addressed in Ukraine. Even that could have been via VPN, and the bitchbot could have been from Russia, Serbia, China or anywhere. Regardless, was a spambot, so I killed it with fire. The fact that our new friend Jasmine here did not respond in any way to my tart query strongly suggests to me that this OP was just the establishment phase of a user able to be activated for spamming in a week, or 3 or 10.
